Page 1 of 2
Re: RA cam
Posted: Thu Sep 27, 2012 11:12 am
by jsclownfish
sorry, I haven't figured out the 'feed' process yet. I just use the weblink and apps from D-link to monitor it. It's a little clunky (probably my home internet speed). I'd like to set it up as a feed independent from that system at some point.
-Jon
Re: RA cam
Posted: Thu Sep 27, 2012 11:19 am
jsclownfish wrote:sorry, I haven't figured out the 'feed' process yet. I just use the weblink and apps from D-link to monitor it. It's a little clunky (probably my home internet speed). I'd like to set it up as a feed independent from that system at some point.
-Jon
You need to do a port forwarding to your webcam and then you can access the page directly from your external ip and whatever port you setup.
Re: RA cam
Posted: Thu Sep 27, 2012 11:20 am
by jsclownfish
Here is a snapshot from my camera if you're interested. The container on the other side of the tank was a "hospital" to seperate out a big Rhodactis that was either dividing or dying and I didn't want to lose it in the rockwork.
The great thing about the suction cup arm is that I can move it around the tank to focus on different corals and such without building another mount. I really don't have a good place to mount a panning camera in front of the tank.
-Jon
- tankpic.JPG (74.08 KiB) Viewed 11136 times
Re: RA cam
Posted: Thu Sep 27, 2012 2:21 pm
Beautiful. Love the yellow tang peeking from below
We really need to find a good wide angle for this cam
Re: RA cam
Posted: Thu Sep 27, 2012 9:33 pm
by jsclownfish
Thanks, I'll check the port forward. I think it is set-up, but just blocked at my work firewall.
Ever since I put this on the tank, I've been wanting to code in a trigger for the autofeeder so I can get all the fish to come to the camera when I want to see them.
Alex,
How did you get your feed to show up on your forum post?
-Jon
Re: RA cam
Posted: Fri Sep 28, 2012 12:47 am
by alexwbush
I'm pretty sure it depends on your webcam, but to post a live feed, I used:
http://wolfpack06.no-ip.org:1984/videostream.cgi?user=user&pwd=password
So I have my no-ip setup in there to link back to the camera and user/password for a guest account. You can't control the camera
When doing port forwarding, I highly recommend using a port other than 80 since that's the most frequently blocked.
Re: RA cam
Posted: Wed Oct 03, 2012 2:39 pm
by jsclownfish
Have you seen those plexiglass boxes/containers the fish stores use so you can look at corals overhead without the ripples in the water? I was thinking about trying to mount my camera over one of those so that it wasn't so "ugly" on the side of the tank. It would be a smaller view, but the camera in theory would be enclosed in the hood.
-Jon
Re: RA cam
Posted: Thu Oct 04, 2012 11:17 pm
by alexwbush
I think those would work great short term. But what if the power cord gets to the water? I just need to wait for HD IP cams to drop in price and raise in quality.
RA cam
Posted: Sat Oct 06, 2012 5:26 am
Just ordered one of these mounts and this fish eye lens... Let's see what it can do!
http://gorillagadgets.com/cellphone-fis ... html?sl=EN
Re: RA cam
Posted: Wed Nov 21, 2012 1:26 pm
Does anyone know how to place a component to a webpage to watch your stream?
Is it camera specific?
Re: RA cam
Posted: Wed Nov 21, 2012 2:46 pm
rimai wrote:Does anyone know how to place a component to a webpage to watch your stream?
It probably is camera specific. On my IP camera, you have to grab the stream by looking at the pages it generates. That's how dave displays my ip camera on my network inside his Client Suite.
I created a test page that just embedded the default /wifi page and my camera stream. It worked pretty good for me.
RA cam
Posted: Wed Nov 21, 2012 3:12 pm
Mine either you need the app, java, or active-x. The last two are in an html and finally if none of the above, i can url to a live static image. But i'm sure each has it's own. The best strategy for support would be to give a url to embed and whatever works for each camera can be used.
RA cam
Posted: Wed Nov 21, 2012 7:19 pm
Here's the pics with/without the fisheye lens.
Before:
- ImageUploadedByTapatalk1353550562.820361.jpg (60.94 KiB) Viewed 11165 times
After:
- ImageUploadedByTapatalk1353550578.175511.jpg (56.26 KiB) Viewed 11165 times
I'm using the mount that jsclownfish posted and the lens was $20. It really makes a huge difference. One thing though...the lens comes with a magnetic ring with adhesive to hold the lens to the camera. The weight of the lens was causing the ring to shift, so I ended up using some frag glue to secure it to the camera.
Re: RA cam
Posted: Wed Nov 21, 2012 9:15 pm
by jsclownfish
Thanks for the update on the lens. That's pretty cool. I'll have to give it a try.
-Jon
Re: RA cam
Posted: Thu Nov 22, 2012 3:44 am
Yeah, that's really sweet!!!
I'm gonna try it too
Thanks for sharing!!!
Re: RA cam
Posted: Sat Mar 09, 2013 6:23 pm
by Redadeath
i have easy n camera and i usually ask to choose activex - java -or app and to sed as default
what king of os does the client suite use
Re: RA cam
Posted: Sun Mar 10, 2013 9:09 am
Redadeath wrote:i have easy n camera and i usually ask to choose activex - java -or app and to sed as default
the client suite is written for windows.
Re: RA cam
Posted: Sun Mar 24, 2013 12:39 pm
by rossbryant1956
the dlink allows you to just call the outside IP address and the port you previously setup forwarding on (like we did with 2000 for the RA.) Try hitting mine at 69.250.225.122:3462
if it asks for a id and password use "guest" and "fishtanks"
LMK if this works
I am still working with the X10 cameras to get them up from a browser
RA cam
Posted: Sun Mar 24, 2013 12:43 pm
Its working...but it didn't prompt for authentication....
Re: RA cam
Posted: Wed Aug 27, 2014 8:32 pm
by sherman
I sign in. Only show black screen. Why? Is it the cam is off
Re: RA cam
Posted: Thu Aug 28, 2014 4:16 am
Night time
Re: RA cam
Posted: Fri Oct 31, 2014 6:37 am
by Ron Starc
IP Camera Viewer for the pc is a excellent free software to view your IP and USB cameras. The interface is intuitive and it works well with every model of IP & USB camera.
