I'm going to load this code and see what I can find out.
The wizard saves the choices you made everytime you quit the application.
If you open again, it will have the same choices of your last code.
Bug on v0.9.6
00Warpig00
Re: Bug on v0.9.6
I used the Reef Angel Wizard to do some process of elimination.
I have successfully and repeatedly been able to make the problem appear/disappear.
Using the wizard I did the following
Memory Settings = In The Code
Temperature *F (probably doesnt matter but thats what I picked 86.0* setpoint)
Expansion Modules = nothing checked
Attachments = Wifi only
Main Relay Box Ports 1-8 = all checked "Not Used" (no port mode check marks)
Daylight Dimming = None
Actinic Dimming = None
WiFi Attachment Username 00Warpig00
Generate
This will produce the following code
This code WILL WORK FINE
Then I created another code using the wizard a second time. This time I did the following...
Expansion Modules = Relay Only
Expansion Relay Box Ports 1-8 = all checked "Not Used" (no port mode check marks)
Generate
This will generate the following code...
This code will show the XML Parser error and will cause the portal to loose connection and not be able to reconnect.
NOTE: the only difference while running the wizard between the two is the selection of the Relay box as well as the "Not Used" selections for each port on the Expansion relay box.
I had Relay Expansion plugged into the USB port on the Main Relay box (eliminating the expansion hub) for both code samples above.
Nick
Generate
InternalMemory.OverheatTemp_write( 860 );
ReefAngel.Portal( "00Warpig00" );
Generate
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
// Date and Time
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
Try this command on the wifi attachment:
Let me know if it solves the problem.
set c s 1420
00Warpig00
Re: Bug on v0.9.6
set comm size 1420
This appears to have resolved the issue at this time. I can now use both the Portal and the Android app the portal doesn't seem to have any trouble connecting so far nor do I get any parser errors in the android app at this time. Keeping an eye on it for now, but I was able to get it to fail within minutes and I have been messing around with it for the past hour with no trouble so far.
Thanks Roberto
Nick
Thanks Roberto
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
Cool.
I'll add that to the wifi utility.
I remember that Dave added that setting to his utility in the past too.
The reason is that the default packet size is 450 bytes, so when you added the relay expansion module to the code, the size of the data stream went above 450 and the wifi attachment was splitting the payload in 2 packets.
I guess some routers don't like that and causes problems when you try to read the entire stream.
00Warpig00
Re: Bug on v0.9.6
I think the culprit may have been the wifi attachment.ttl script you sent me earlier in the thread to config the wifi.
That ttl script has sendln 'set c s 2048' in it.
BTW still working without issue. I get a url timeout once in a while from my android. but a subsequent refresh connects me and no more parser errors. The portal still is having no trouble. I have reverted to my full loaded code and it still is working fine.
Nick
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
