Wave patterns
Smotz
Re: Wave patterns
Post by Smotz »
rimai wrote:Not with this function.
You will need to use another custom function with whatever wave pattern you want.
Let me see if I understand...
The wave is going to be random between 35% and 70% for 5 seconds, 70% for 5 seconds and 0% for 1 second?
Weird one :roll: , but we can definitely do it... :mrgreen:
I guess. I am just trying to (logically) figure out a wave pattern with just 1 pump (and the return pump)
Re: Wave patterns
Add this to the end of your code:
byte MyCustomWave(byte maxspeed)
  static byte randomspeed=0;
  if (now()%11<5)
    return randomspeed;
  else if (now()%11>=5 && now()%11<10)
    return maxspeed;
    randomspeed=random(35,maxspeed);
    return 0;
And call your function like this:
  ReefAngel.PWM.SetActinic(MyCustomWave(70));
Smotz
Re: Wave patterns
Post by Smotz »
rimai wrote:Add this to the end of your code:
  if (now()%11<5)
    return randomspeed;
    return maxspeed;
    return 0;
Wow man, Thanks!
Can I ask you to help me understand this a bit? - Teach a man to fish sort of thing?
Can you explain what the %11 is? I assume it's the variable for the duration but I don't understand how it got defined..?
How would I alter this to Random wave, pause for 1 sec, etc ?
would this do it? (but it looks to me like it waits for 5 seconds?)
if (now()%11<5)
return randomspeed;
return 0;
Re: Wave patterns
The %11 is a mathematical computation. The % is actually called modulus. It takes the remainder of the division operation. When he is using the %11, he is taking the number of seconds (now()) and breaking it down into 11 segments with each segment being 1 second. The first part of his code, now()%11<5 is checking for seconds 0-4 inclusive (which is 5 seconds). The second part, now()%11>=5 && now()%11<10, is checking for seconds 5-9 inclusive (which is 5 seconds) and then the last scenario is simply 1 second.
What ends up happening is the first IF runs for 5 seconds, the next IF runs for 5 seconds and the last IF runs for 1 second then the whole process repeats over and over again every 11 seconds no matter what time of day it is.
Your code you put down:
if ( now()%11 < 5 )
return randomspeed;
return 0;
Will run the first part for 5 seconds and the second part for 6 seconds. So run for 5 seconds, pause for 6 seconds, repeat.
Smotz
Re: Wave patterns
Post by Smotz »
thanks curt. Much appreciated. I kinda get it - doing will really teach me. I am so glad i went reef angel. I am learning a lot.
Wave patterns
Smotz wrote:thanks curt. Much appreciated. I kinda get it - doing will really teach me. I am so glad i went reef angel. I am learning a lot.
+1 try doing any of this with an apex! Not possible!
Smotz
Re: Wave patterns
Post by Smotz »
binder wrote:The %11 is a mathematical computation. The % is actually called modulus. It takes the remainder of the division operation. When he is using the %11, he is taking the number of seconds (now()) and breaking it down into 11 segments with each segment being 1 second. The first part of his code, now()%11<5 is checking for seconds 0-4 inclusive (which is 5 seconds). The second part, now()%11>=5 && now()%11<10, is checking for seconds 5-9 inclusive (which is 5 seconds) and then the last scenario is simply 1 second.
if ( now()%11 < 5 )
return randomspeed;
return 0;
SOOO. If I change the 11 to a 7 - the first part will run for 5 seconds and the second for 2?
Re: Wave patterns
that is correct.
Robert1969
Re: Wave patterns
Post by Robert1969 »
ok Im a little lost. have had my WP40 cable for about a week and thought I would try to get my Jabao pump set up.
If I understand it correctly all I have to do is add a code from page 1, of this topic, between the lines "Place your custom code below/above here" on my sketch.
I can add this code from page 2 and it works fine:
   byte random_speed=35;
if (now()%5==1) random_speed=random(35,70);
ReefAngel.PWM.SetDaylight( LongPulseMode(random_speed,70,5,true));
But if I add lets say the "Reefcrest" code from page 1:
    byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
  static unsigned long lastwavemillis=millis();
  static int newspeed=WaveSpeed;
  if ((millis()-lastwavemillis) > 5000)
    if (random(100)<50) newspeed--; else newspeed++;
    newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
    newspeed=constrain(newspeed,0,100);
  if (PulseSync)
    return newspeed;
    return WaveSpeed-(newspeed-WaveSpeed);
I get the following error from Arduino: a function-definition is not allowed here before{token
Do I need to do something to the code before adding it to my sketch?
Thanks for any help
Smotz
Re: Wave patterns
Post by Smotz »
The definition (the latter part) is longer needed in the updated libraries
Robert1969
Re: Wave patterns
Is the definition part everything between { } ?
enigma32
Re: Wave patterns
Post by enigma32 »
And the line above it.
He's saying the whole function no longer needs to be manually added in your code:
  if (PulseSync)
    return newspeed;
Current setup:
AI Sol Blue, Ecotech MP-10wES
Coralife skimmer
Robert1969
Re: Wave patterns
Ok I'm confused. What do I add then if I want the reef crest mode?
Wave patterns
You just use the function...you no longer need to have the whole section in your code that was in the last post
Robert1969
Re: Wave patterns
What part is the function. Sorry for all the noob questions most of the time I feel so lost with this thing
Wave patterns
The function is part of the libraries.
You use it by setting the port connected to your pump with the result of the function like this...
ReefAngel.PWM.SetActinic( ReefCrestMode(45,10,true));
You put a line like that inside your loop section.
Robert1969
Re: Wave patterns
Oh ok. Thank you
Re: Wave patterns
So If I wanted a Long Pulse and my WP40 is plugged into my daylights i would do something like this...
ReefAngel.PWM.SetDaylight( LongPulseMode(45,10,true));
What is the 45,10 the pump speed and wave length?
Also what does the true do?
Wave patterns
45 is the % 10 is the time between pulses and true means sync.
If you had two pumps you could set one true and one false for an anti sync effect.
Re: Wave patterns
That's what I thought.
45 is the % of speed.
What format is the time in, seconds or milliseconds?
Re: Wave patterns
It's in the original post :)
Each function has a different unit. Short Pulse and NTM are milliseconds, but Long Pulse is seconds.
Also, your code is missing one parameter. It's supposed to be 4 total.
Check the original post.
Re: Wave patterns
Sorry Roberto. Like I said I'm a complete noob to coding.
It looks like I left out the PulseMinSpeed or PulseMaxSpeed.
So would it be like this?
ReefAngel.PWM.SetDaylight( LongPulseMode(45,70,10,true));
Re: Wave patterns
Yes :)
You got it :)
Re: Wave patterns
Thanks for making me figure it out.
Again "Teach a man to fish".
SaltyGXP
Re: Wave patterns
Post by SaltyGXP »
So I've scanned throughout the last 5 or so pages and didn't see it. Is there ant way we can get Lagoon mode add to the wave patterns?
Dustin
Re: Wave patterns
Well, Lagoon is nothing more than reefcrest with a very close min and max range.
Re: Wave patterns
Ok I got most everything setup last night.
There's only a couple of things I need to tackle still, but the first and what seems to be the easiest is hooking up and coding the WP40.
I know all the wave patterns are on the first page (Thank Roberto), but can someone equate them to the different modes on the WP40?
H: High, constant, non-variable flow (13,000 LPH)
L: Low, constant, non-variable flow at a third of the speed (4,300 LPH)
W1: Short pulses which, when timed correctly will create a back and forth motion and form a gentle standing wave in your tank. Adjust the controller to change the speed of the pulses and vary the size of the wave according to your tank.
W2 & W3: Pump gradually speeds up and slows down incrementally to create a varied flow pattern. Adjustable to form the wave best suited to your tank.
Else: Reef Stream Mode, a mixed, changing pattern that creates a random flow cycle similar to what you would find in a natural reef.
I currently use W1 on a slow speed 16-18V and a medium wave length.
coolbird
Re: Wave patterns
Post by coolbird »
Could I just ask as I may be looking at this a bit to simplistically:
I have 2x wp40's that I want to connect to my light ports and for example I want a long pulse minimum power at 10% maximum at 50 lasting for 20 seconds each anti-sync I would enter the below into my loop?
ReefAngel.PWM.SetDaylight( LongPulseMode(10,50,20,true))
ReefAngel.PWM.SetActinic( LongPulseMode(10,50,20,false))
Dave
Re: Wave patterns
I'm just getting into coding and by no means am an expert, but this looks correct.
The criteria for Long Pulse is...
Long Pulse
PulseMinSpeed - % for minimal speed
PulseMaxSpeed - % for maximum speed
PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
coolbird
Re: Wave patterns
Post by coolbird »
Sacohen wrote:I'm just getting into coding and by no means am an expert, but this looks correct.
Long Pulse
Hi Sacohen
Its how I see it as well; I should thank you really as you have been asking all the questions I would have put :-)
We will see what the masters of the "black art" say, I hope we are both not mistaken :oops:
Thanks again
Dave
