Bug on v0.9.6
Re: Bug on v0.9.6
Redid the push to the controller and it went through, but now it looks like my wifi isnt working properly
when i go to the website ip address:2000\wifi i get this
<script language="javascript" src="http://www.reefangel.com/wifi/ra1.js"/>
Re: Bug on v0.9.6
Ok looks like that did it, I had to reprogram the wi-fi unit and I can see the expansion relay now in the portal and the banner. I did lose the ability to see the RF module and the PWM module in the portal
Re: Bug on v0.9.6
https://github.com/reefangel/Libraries/issues/11projectx wrote:Redid the push to the controller and it went through, but now it looks like my wifi isnt working properly
This issue has been logged.
Thanks.
Re: Bug on v0.9.6
Can you open a new thread for this?projectx wrote:Ok looks like that did it, I had to reprogram the wi-fi unit and I can see the expansion relay now in the portal and the banner. I did lose the ability to see the RF module and the PWM module in the portal
Re: Bug on v0.9.6
By all means
Sent from my Galaxy Nexus using Tapatalk 2
Re: Bug on v0.9.6
I believe I am having this issue with the 1.0.0 Libraries.rimai wrote:https://github.com/reefangel/Libraries/issues/11projectx wrote:Redid the push to the controller and it went through, but now it looks like my wifi isnt working properly
Thanks.
Both my private and public IP addresses give me this result.
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Connection: close
Content-Type: text/html
Content-Length: 82
<script language='javascript' src='http://www.reefangel.com/wifi/ra1.js'></script>
Portal says my wifi address is invalid but it's not. Portal Dashboard says it needs a valid address to my controller to allow me to toggle relays etc.
Also getting 'Error 23: XML SAX Parser" when trying to refresh from controller in Android app 0.6.1
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
I'm testing on v1.0.0 and I get correct results.
Which browser are you using?
Can you wireshark and post the tcp stream?
Re: Bug on v0.9.6
Browser related...
IE 9 Gives me "Reef Angel Controller Web Server"
Firefox 13.0.1 Gives me
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Connection: close
Content-Length: 82
The Portal is still telling me my wifi address is not valid so I have no remote control.
Also still getting the "Error 23: XML SAX Parser" error in the Android app
Nick
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Connection: close
Content-Length: 82
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
Started tracking my issue down.00Warpig00 wrote:Browser related...
Nick
my problem is directly related to one variable. The line of my code that causes this issue is...
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,1,100,1) );
to highlight the variable that causes my issue I have changed it to an x in the following line
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,x,100,1) );
it appears as if this variable is set to "1" I get all of the symptoms listed below
Portal cannot connect to my wifi "Unreachable Address"
Android app shows me "Error 23: XML SAX Parser"
I have tested with that variable set at 0 1 2 3 and the ONLY one that results in these symptoms is "1"
So I have tried
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,0,100,1) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,2,100,1) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,3,100,1) );
all those seem to work for me, but not
Here is my PWM code lines as they sit with the issue. The middle line is the offending line.
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,3,100,3) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(0,0,10,0,15,100,2,15) );
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
Wow. Nice troubleshooting.
Let me look into what happens within the parabola function when you use the 1 parameter.
Re: Bug on v0.9.6
I can't seem to be able to replicate the issue.
Is there any particular window frame that this happens or is it all the time?
Re: Bug on v0.9.6
Here is my complete code with the problem. Maybe it matters.
code generated by install wizard.
Im using 1.0.0 libs.
all the hardware I bought from you is plugged in on the bench except any probes or float switches or LED drivers. IE all modules are plugged in however no input devices are... except temp probes. They are pluged in.
I miss spoke earlier. I still seem to get the XML Parser error on My Android most of the time but at least now my android controls the relay boxes and the Portal can connect to my controller. I have made NO changes to anything except that one line of code. to get this far. right now I am using the line to match the one above it except addressing it to PWM port 1
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,3,100,3) );
using this line I dont get the Parser error. but changing the two 3.'s on that line and experimenting with different values causes the parser error to sometimes appear. particularly if i use a line like..
this gives me a parser error most all the time on my droid app but I can still control relay boxes.
and the portal can still find my controller
Nick
byte buzzer=0;
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.FeedingModePortsE[0] = Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.StandardFan( Port1,790,820 );
ReefAngel.StandardATO( Port2,60 );
ReefAngel.Relay.DelayedOn( Port4,5 );
ReefAngel.WavemakerRandom( Port5,30,100 );
ReefAngel.StandardHeater( Port6,751,761 );
ReefAngel.StandardLights( Box1_Port1,14,0,23,0 );
ReefAngel.StandardLights( Box1_Port2,14,0,23,0 );
ReefAngel.StandardHeater( Box1_Port3,751,761 );
ReefAngel.StandardHeater( Box1_Port4,751,761 );
ReefAngel.Portal( "00Warpig00" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// I/O Expansion
byte bkcolor;
x = 14;
y = 34;
if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
ReefAngel.LCD.DrawMonitor( 15, 44, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 44, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,76, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,76, ReefAngel.Params.Salinity );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 104, TempRelay );
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
Ok, so just to confirm that it is indeed the parabola that is causing it, can you set the channels to:
By doing so, do you still get xml parser errors?
ReefAngel.PWM.SetChannel( 0, 10 );
ReefAngel.PWM.SetChannel( 1, 10 );
ReefAngel.PWM.SetChannel( 2, 10 );
Re: Bug on v0.9.6
I will try your code in a minute. While I was out to dinner I played with the Android app a bit. I'm not exactly sure whats going on with the "Error 23: XML SAX Parser" issue. I have not identified a pattern yet but with the following code...
The Portal seems to be fine connecting with my controller at this point.
I am still having the Parser error show up in the android app. Seems as if the android app is having trouble and cannot update UI of the app or is not reading data correctly from the controller. IE I can still turn outlets on and off but If I exit the App and go back in it may not show the correct state of the outlet. I can still flip the outlet on/off but I see the parser error every time I touch anything in the app.
It has worked a couple times without error... but it seems to be immediately after I upload to and boot the controller that it may work with no parser error.
Going to try your code now. Back in a few with results.
Nick
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
rimai wrote:Ok, so just to confirm that it is indeed the parabola that is causing it, can you set the channels to:By doing so, do you still get xml parser errors?Code: Select all
ReefAngel.PWM.SetChannel( 0, 10 ); ReefAngel.PWM.SetChannel( 1, 10 ); ReefAngel.PWM.SetChannel( 2, 10 );
This seems to take care of the Parser issue. I touched the update button about 25 times while holding one or two termp probes and was watching the temp climb. I would hit refresh about every 5 seconds. 90% of the time no parser errors. I did see one or two out of about 25 touches but the app said connecting... for about 5 seconds before the error (seemed more like a timeout) a subsequent touch of refresh would go through and update the screen with no errors. Before I was lucky to get one without an error then all subsequent would error.
However now the Portal says my controller is unreachable again... lol
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
I am SO CONFUSED at this point! The parser error has got to be related to something else... I have completely removed all the PWM lines and uploaded to the controller. was working fine with no parser errors for about 10 refreshes... then BAM! Parser error. now it wont work again and all I get is parser errors. This is crazy!
Rebooted controller and wifi mod... nothing but parser errors now.
time to dumb everything down... unplugging EVERYTHING except main relay box wifi mod and temp sensors and going back to default load...
Nick
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
Let's try resetting the wifi attchment.
But this time, I want you to use a different route to set it up.
First, use the wifi utility to factory reset it.
Please download TeraTerm: http://www.rovingnetworks.com/resources ... 6/Teraterm
Then decompress and edit the wifi attachment.ttl file with your ssid and passphrase.
Start Tera Term and connect to your wifi attachment at 9600 baud using the correct serial com port.
Execute the macro with menu Control->Macro
Let me know if this changes anything.
- wifi attachment.zip
- (711 Bytes) Downloaded 454 times
Re: Bug on v0.9.6
Here is a paste of my tera term results. i have changed a few characters in my WIFI key to keep it protected for now until I change it later. but I wanted everyone with this issue to see the results as it may be helpful to others
CMD
factory RESET
Set Factory Defaults
<2.32> reboot
*Reboot*WiFly Ver 2.32, 02-13-2012 on RN-131
MAC Addr=00:06:66:30:07:6a
Auto-Assoc roving1 chan=6 mode=NONE FAILED
*READY*
CMD
set ftp address 208.109.14.133
AOK
<2.32> save
Storing in config
<2.32> set wlan ssid 2WIRE993
AOK
<2.32> set wlan pass -dx?(X-Ksc%<&jk51l>vn^Bq8D6yB%^yOTlT7P6E/MvR_,#baV.Jt7-pksCh#=z
AOK
<2.32> set option deviceid ReefAngelWifi
AOK
<2.32> set c c 0
AOK
<2.32> set c r 0
AOK
<2.32> set c o 0
AOK
<2.32> set c i 3
AOK
<2.32> set c s 2048
AOK
<2.32> set dns name www.reefangel.com
AOK
<2.32> set i h 198.171.134.6
AOK
<2.32> set i r 80
AOK
<2.32> set i f 0x6
AOK
<2.32> set s t 0x10
AOK
<2.32> set u m 2
AOK
<2.32> set i p 2
AOK
<2.32> save
Storing in config
<2.32> reboot
Auto-Assoc 2WIRE993 chan=1 mode=WPA2 SCAN OK
Joining 2WIRE993 now..
*READY*
Associated!
DHCP: Start
DHCP in 2024ms, lease=-1s
IF=UP
DHCP=ON
IP=192.168.128.200:2000
NM=255.255.255.0
GW=192.168.128.254
Listen on 2000
CMD
ftp u wifly-235.img
<2.32> FTP connecting to 208.109.14.133
FTP file=34
FTP OK.
UPDATE OK
ftp r wps.img
FTP file=66
FTP OK.
set u b 57600
AOK
<2.32> set s p 0
AOK
<2.32> save
Storing in config
<2.32> save user
Storing in user
<2.32> reboot
It appears to be working as of now with the base RA load and only the temp probes and main relay box connected. i am headed to lunch now and will try remotely.
Nick
CMD
factory RESET
<2.32> reboot
*READY*
CMD
AOK
<2.32> save
Storing in config
AOK
AOK
AOK
<2.32> set c c 0
AOK
<2.32> set c r 0
AOK
<2.32> set c o 0
AOK
<2.32> set c i 3
AOK
<2.32> set c s 2048
AOK
AOK
AOK
<2.32> set i r 80
AOK
<2.32> set i f 0x6
AOK
<2.32> set s t 0x10
AOK
<2.32> set u m 2
AOK
<2.32> set i p 2
AOK
<2.32> save
Storing in config
<2.32> reboot
*READY*
Associated!
DHCP: Start
IF=UP
DHCP=ON
NM=255.255.255.0
GW=192.168.128.254
Listen on 2000
CMD
ftp u wifly-235.img
FTP file=34
FTP OK.
UPDATE OK
ftp r wps.img
FTP file=66
FTP OK.
set u b 57600
AOK
<2.32> set s p 0
AOK
<2.32> save
Storing in config
<2.32> save user
Storing in user
<2.32> reboot
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
MUST be something somewhere in the code generated by the RA Install wiz or libs. After it was working all afternoon on the base RA load I decided to plug in ONLY the expansion hub and the Expansion relay module/box.
loaded the following code as it sits here... I commented some stuff in/out (commented //wp)
to try to make at least the setup portion more like the RA base load setup to see if I could find the issue.
Uploaded the following to the RA+ and the XML Parser error instantly came back on my android app and the Portal is having intermittent issues connecting to my RA+ (earlier Tera Term Wifi config still in place).
I am very rusty in programming. I have a feeling that is gonna have to change. lol So I have not gone into the libraries at all at this time. Is there a way to launch the wizard that built this code for me so I can re-do it and start basic and add one piece back at a time? May help troubleshoot and I'm a bit rusty at this point to do it by hand without breaking the code.
Nick
//wp #include <InternalEEPROM.h> //duplicate line - see above
//wp byte buzzer=0;
ReefAngel.AddStandardMenu(); //wp added
ReefAngel.AddDateTimeMenu(); //wp added
//wp ReefAngel.WaterChangePorts = Port3Bit | Port4Bit;
//wp ReefAngel.WaterChangePortsE[0] = 0;
//wp ReefAngel.TempProbe = T1_PROBE;
//wp InternalMemory.OverheatTemp_write( 850 );
//wp ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,3,100,3) );
//wp ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,1,100,1) );
//wp ReefAngel.PWM.SetChannel( 2, PWMSlope(0,0,10,0,15,100,2,15) );
//wp ReefAngel.PWM.SetChannel( 0, 10 );
//wp ReefAngel.PWM.SetChannel( 1, 10 );
//wp ReefAngel.PWM.SetChannel( 2, 10 );
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// I/O Expansion
byte bkcolor;
x = 14;
y = 34;
// Salinity
// Relay Expansion
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
I'm going to load this code and see what I can find out.
The wizard saves the choices you made everytime you quit the application.
If you open again, it will have the same choices of your last code.
Re: Bug on v0.9.6
I used the Reef Angel Wizard to do some process of elimination.
I have successfully and repeatedly been able to make the problem appear/disappear.
Using the wizard I did the following
Memory Settings = In The Code
Temperature *F (probably doesnt matter but thats what I picked 86.0* setpoint)
Expansion Modules = nothing checked
Attachments = Wifi only
Main Relay Box Ports 1-8 = all checked "Not Used" (no port mode check marks)
Daylight Dimming = None
Actinic Dimming = None
WiFi Attachment Username 00Warpig00
Generate
This will produce the following code
This code WILL WORK FINE
Then I created another code using the wizard a second time. This time I did the following...
Expansion Modules = Relay Only
Expansion Relay Box Ports 1-8 = all checked "Not Used" (no port mode check marks)
Generate
This will generate the following code...
This code will show the XML Parser error and will cause the portal to loose connection and not be able to reconnect.
NOTE: the only difference while running the wizard between the two is the selection of the Relay box as well as the "Not Used" selections for each port on the Expansion relay box.
I had Relay Expansion plugged into the USB port on the Main Relay box (eliminating the expansion hub) for both code samples above.
Nick
Generate
InternalMemory.OverheatTemp_write( 860 );
Generate
int x,y;
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
Try this command on the wifi attachment:
Let me know if it solves the problem.
set c s 1420
Re: Bug on v0.9.6
set comm size 1420
This appears to have resolved the issue at this time. I can now use both the Portal and the Android app the portal doesn't seem to have any trouble connecting so far nor do I get any parser errors in the android app at this time. Keeping an eye on it for now, but I was able to get it to fail within minutes and I have been messing around with it for the past hour with no trouble so far.
Thanks Roberto
Nick
Thanks Roberto
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
Re: Bug on v0.9.6
Cool.
I'll add that to the wifi utility.
I remember that Dave added that setting to his utility in the past too.
The reason is that the default packet size is 450 bytes, so when you added the relay expansion module to the code, the size of the data stream went above 450 and the wifi attachment was splitting the payload in 2 packets.
I guess some routers don't like that and causes problems when you try to read the entire stream.
Re: Bug on v0.9.6
I think the culprit may have been the wifi attachment.ttl script you sent me earlier in the thread to config the wifi.
That ttl script has sendln 'set c s 2048' in it.
BTW still working without issue. I get a url timeout once in a while from my android. but a subsequent refresh connects me and no more parser errors. The portal still is having no trouble. I have reverted to my full loaded code and it still is working fine.
Nick
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
