I recently upgraded to the .9.8 lib. this fixed a problem with my expansion relays not showing in the portal or on the web banner. But now I am experiencing an issue that my RF expansion and my PWM expansion are not showing in the portal.
Any ideas?
RF and PWM modules not showing in Portal
projectx
Re: RF and PWM modules not showing in Portal
// Autogenerated file by RAGen (v1.2.2.171), (05/29/2012 11:15)
// RA_052912_1115.ino
#define DisplayImages
#define SetupExtras
#define DosingPumpSetup
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define DisplayLEDPWM
#define wifi
#define SingleATOSetup
#define RelayExp
#define DosingPumpIntervalSetup
#define PWMEXPANSION
#define ENABLE_ATO_LOGGING
#define ENABLE_EXCEED_FLAGS
#define RFEXPANSION
ReefAngel.FeedingModePorts = Port5Bit | Port3Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
ReefAngel.LightsOnPortsE[1] = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Box1_Port3);
ReefAngel.SingleATOLow(Port1);
ReefAngel.MHLights(Port4);
ReefAngel.DosingPumpRepeat1(Port7);
ReefAngel.DosingPumpRepeat2(Port8);
ReefAngel.MHLights(Box1_Port5);
ReefAngel.MHLights(Box1_Port6);
ReefAngel.StandardLights(Box1_Port1, 21, 0, 9, 0);
ReefAngel.StandardLights(Box1_Port2, 21, 0, 9, 0);
// PWMSlope based on Internal Memory values for Standard Lights
ReefAngel.Portal("projectx");
#define SetupExtras
#define VersionMenu
#define ATOSetup
#define wifi
#define RelayExp
#define RFEXPANSION
projectx
Oh carp I don't have the channels defined. Nor do I have the rf defined. Must have been a fluke that they showed up in the portal before w the same code
Sent from my Galaxy Nexus using Tapatalk 2
projectx
Ill chalk this one up to a PICNIC error
problem in chair not in controller lol
