Hi, I would like to Know if is possible to control one port with a pH value??
Exemple: pH under 7,5 air pump On
pH 8 air pump Off
Thank for you help
Control port with pH value ??
Osaka 40g with 55g sump
Radion, 2X Tunze 6045, Swc-160 mini cone
Re: Control port with pH value ??
What version of libs are you using?
On v0.9.9, you can use:
ReefAngel.PHControl( Port1,750,800);
Wow!!!
You never sleep Roberto?
Thank you very much i will try this (tup)
rimai wrote:What version of libs are you using?
On v0.9.9, you can use:Code: Select all
I try this for test and not work, I have libs v0.9.9
This is my code generate with de wizard and mod for PH control, sorry i'm very newbie to make a code
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.DosingPumpRepeat( Port8,0,60,6 );
ReefAngel.PHControl( Port6,750,800);
This code works just fine for me.
Turns on when pH is less than 7.50 and off when pH is over 8.00
Ok it's work fine...the problem was my interpretation
When i tested, the Ph in my tank indicate 7.8 and the Ph control is on 7.5 and off 8.0 my port is On, cause my ph is 7.8 (i was thinking is Off) i have try with different value like on 7.5 and off 7.7 and its work, my port is off cause my ph is 7.8
I dont know if i'm clear, but the most important it's this code is good
thank you very much, the Reef Angel is the best controller in the world i'm very happy with my purchase
