Problem with dev library 1.0.0
Re: Problem with dev library 1.0.0
Add this to the INO file?
on the screen it is also showing nothing % wise.
yes in the app I verified that it was unchecked
Yes, add to setup().
Did you uncomment the line you had previously commented that would display the % on the screen?
Yes I removed the line of code.
Ill add the other line and report back
Thanks for your help as always
Added that line and same result with the Vortech on both the Portal as well as the App
for now it seems my ATO is working properly.
The PWM I will have to recheck tomorrow as it is past the time for the lights to be active.
When you compile, does it show it found the RF Expansion feature?
So the PWM is working ok now.
my ATO is still not working properly and here is the copy of the complile
avrdude: Recv: p [70]
avrdude: Recv: r [72]
avrdude: Recv: o [6f]
avrdude: Recv: j [6a]
avrdude: Recv: e [65]
avrdude: Recv: c [63]
avrdude: Recv: t [74]
avrdude: Recv: x [78]
avrdude: Recv: . [00]
avrdude: Recv: . [2e]
avrdude: Recv: 0 [30]
avrdude: Recv: m [6d]
avrdude: Recv: l [6c]
avrdude: Recv: h [68]
avrdude: Recv: . [0d]
avrdude: Recv: . [0a]
avrdude: Recv: G [47]
avrdude: Recv: E [45]
avrdude: Recv: T [54]
avrdude: Recv: [20]
avrdude: Recv: / [2f]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: w [77]
avrdude: Recv: i [69]
avrdude: Recv: f [66]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: b [62]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: a [61]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: v [76]
avrdude: Recv: [20]
avrdude: Recv: d [64]
avrdude: Recv: H [48]
avrdude: Recv: P [50]
avrdude: Recv: 1 [31]
avrdude: Recv: [20]
avrdude: Recv: s [73]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: < [3c]
avrdude: Recv: V [56]
avrdude: Recv: > [3e]
avrdude: Recv: R [52]
avrdude: Recv: M [4d]
avrdude: Recv: I [49]
avrdude: Recv: N [4e]
avrdude: Recv: O [4f]
avrdude: Recv: D [44]
avrdude: Recv: A [41]
avrdude: Recv: Y [59]
avrdude: Recv: C [43]
avrdude: Recv: n [6e]
avrdude: Recv: [20]
avrdude: Send: . [1b] - [2d] . [00] . [04] . [0e] . [14] . [01] . [00] [20] . [09]
avrdude: Recv: . [1b]
avrdude: Recv: - [2d]
avrdude: Recv: . [01]
avrdude: Recv: . [03]
avrdude: Recv: . [0e]
avrdude: Recv: . [14]
avrdude: Recv: k [6b]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: ^ [5e]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: ` [60]
avrdude: Recv: [20]
avrdude: Recv: : [3a]
avrdude: Recv: 2 [32]
avrdude: Recv: 3 [33]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: g [67]
avrdude: Recv: W [57]
avrdude: Recv: S [53]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: & [26]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: F [46]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: u [75]
avrdude: Recv: [20]
avrdude: Recv: = [3d]
avrdude: Recv: . [ff]
avrdude: Recv: , [2c]
avrdude: Recv: . [02]
avrdude: Recv: . [1c]
avrdude: Send: . [1b] . [2e] . [00] . [04] . [0e] . [14] . [00] b [62] [20] i [69]
avrdude: Recv: . [10]
avrdude: Recv: @ [40]
avrdude: Recv: . [f9]
avrdude: Recv: . [0f]
avrdude: Recv: . [17]
avrdude: Recv: ( [28]
avrdude: Recv: . [1f]
avrdude: Recv: . [1e]
avrdude: Recv: . [06]
avrdude: Recv: . [0c]
avrdude: Recv: . [12]
avrdude: Recv: . [18]
avrdude: Recv: . [d8]
avrdude: Recv: . [05]
avrdude: Recv: . [86]
avrdude: Recv: . [ea]
avrdude: Recv: . [1a]
avrdude: Recv: K [4b]
avrdude: Recv: + [2b]
avrdude: Recv: . [11]
# | 100% 14.73s
avrdude: verifying ...
avrdude: 36450 bytes of flash verified
avrdude: Send: . [1b] / [2f] . [00] . [03] . [0e] . [11] . [01] . [01] ( [28]
avrdude: Recv: ) [29]
avrdude done. Thank you.
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
# | 100% 14.73s
No problem, but it doesnt look like it is recognizing it
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Relay Expansion Module
Dimming Expansion Module
Number of Relay Expansion Modules: 1
Simple Menu
Binary sketch size: 36,450 bytes (of a 258,048 byte maximum)
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Simple Menu
Sorry, just realized that we are missing that keyword in the features auto-selection feature.
So, for now, add this commented line to anywhere your code
//ReefAngel.RF.UseMemory=true;
I think we delt with that the last update lol, so much for learning from my mistakes
what about the ATO Issue, I have it setup in the code as a standardATO, I checked the switch and it is good, goes open when all the way up and closes when down.
StandardATO uses 2 float switches.
http://forum.reefangel.com/viewtopic.php?f=7&t=240
Are you using both? One facing up and one facing down?
Ah no shoot I am my own worst enemy I am using 1 switch
Sent from my Galaxy Nexus using Tapatalk 2
Thanks for your help, I am back to 100% now.
I need to setup my original INO side-by-side with the new one next time.
also added this in //ReefAngel.RF.SetMode(); and the vortech now shows up on the portal
