Wifi attachment commands
PostPosted: Fri Dec 20, 2013 9:24 am
Thanks!!
What you are getting is the intended result. It was a mistake on that post. I corrected it.
It has to be something within your code.
It is not the override as you can see it in here: status/chart.aspx?id=lnevo&filter=rfb
Can you open a new thread?
PostPosted: Fri Dec 20, 2013 9:42 am
I'll start a new thread... just the typo was noticed when I tried to see if the override would help reset it.
PostPosted: Mon Dec 23, 2013 9:34 pm
what is the usage of the /cal command? can it be used to trigger the calibration modes?
PostPosted: Tue Dec 24, 2013 3:10 pm
Yes, I updated the OP :)
PostPosted: Tue Dec 24, 2013 3:31 pm
rimai wrote:Yes, I updated the OP :)
awesome. thanks :)
PostPosted: Thu Apr 10, 2014 1:45 pm
There is no way to read/write a dword (i.e. InternalMemory.read_dword() / InternalMemory.write_dword() )
Need to ad a /md :)
PostPosted: Thu Apr 10, 2014 2:02 pm
Can you add a ticket on github?
Sent from my SPH-L710 using Tapatalk
PostPosted: Thu Apr 10, 2014 2:18 pm
Yeah, I'll add this and need to add HighATOChannel to DCPump :)
PostPosted: Fri Jun 13, 2014 2:55 am
I have the same question, is there a schema for the data that /sr or /sa will return? The answer to genuflect is begged!! :? :? :? :? :? :? :? :?
PostPosted: Fri Jun 13, 2014 8:43 pm
Hamid2 wrote:I have the same question, is there a schema for the data that /sr or /sa will return? The answer to genuflect is begged!! :? :? :? :? :? :? :? :?
If you want to know what the schema looks like, then you need to view the code. It's located in the RA_Wifi/RA_Wifi.cpp file. Here's a link to the github location of the file:
https://github.com/reefangel/Libraries/ ... A_Wifi.cpp
Around line 300, there will be a line that says "case REQ_R_STATUS:"
That section shows the the XML code that is generated by those 2 commands.
Users browsing this forum: Bing [Bot] and 1 guest
