Page 2 of 3
Re: Wifi attachment commands
Posted: Fri Dec 20, 2013 9:24 am
Thanks!!
What you are getting is the intended result. It was a mistake on that post. I corrected it.
It has to be something within your code.
It is not the override as you can see it in here:
http://forum.reefangel.com/status/chart ... filter=rfb
Can you open a new thread?
Posted: Fri Dec 20, 2013 9:42 am
I'll start a new thread... just the typo was noticed when I tried to see if the override would help reset it.
Posted: Mon Dec 23, 2013 9:34 pm
what is the usage of the /cal command? can it be used to trigger the calibration modes?
Posted: Tue Dec 24, 2013 3:10 pm
Yes, I updated the OP
Posted: Tue Dec 24, 2013 3:31 pm
rimai wrote:Yes, I updated the OP
awesome. thanks
Posted: Thu Apr 10, 2014 1:45 pm
There is no way to read/write a dword (i.e. InternalMemory.read_dword() / InternalMemory.write_dword() )
Need to ad a /md
Posted: Thu Apr 10, 2014 2:02 pm
Can you add a ticket on github?
Sent from my SPH-L710 using Tapatalk
Posted: Thu Apr 10, 2014 2:18 pm
Yeah, I'll add this and need to add HighATOChannel to DCPump
Posted: Fri Jun 13, 2014 2:55 am
by Hamid2
Posted: Fri Jun 13, 2014 8:43 pm
If you want to know what the schema looks like, then you need to view the code. It's located in the RA_Wifi/RA_Wifi.cpp file. Here's a link to the github location of the file:
https://github.com/reefangel/Libraries/ ... A_Wifi.cpp
Around line 300, there will be a line that says "case REQ_R_STATUS:"
That section shows the the XML code that is generated by those 2 commands.
Posted: Wed Sep 10, 2014 7:55 am
Any way to add a command to clear a bus lock flag? If it's possible I'll open an issue.
Posted: Wed Sep 10, 2014 8:08 am
No, it clears automatically when the problem is resolved
Posted: Sat Jun 25, 2016 9:24 pm
by soyrex
I could be missing something obvious.. but when I call the waterchange mode from the wifi... how do I take the RA out of WC mode? Do I make the same call again to toggle it?
Posted: Sat Jun 25, 2016 9:54 pm
/bp for button press
Posted: Tue Jun 28, 2016 12:41 am
by soyrex
Of course looking at this now - it makes perfect sense. I'm going to blame being tired.
Do you know if there's a way to check if WC or Feed mode are already active?
Posted: Tue Jun 28, 2016 8:47 am
Yes. The SF flag is an 8 bit representation of different modes.
At the moment, we only use the first 3 bits.
// Status Flag Bits
#define LightsOnFlag 0
#define FeedingFlag 1
#define WaterChangeFlag 2
