I'm still not following.
What do you do to upload again??
Are you disconnecting it?
How can you program controllertest.hex if it was failing before?
You've gotta be doing something that I didn't quite grasp yet
Copy the InitialInternalMemory.hex and controllertext.hex created from RA/Arduino files to a directory
Using Atme Stuido 4 or 6 and the dragon programmer
Erase device
Flash InitialInternalMemory.hex. Fflashes and verifies fine. LCD screen shows Internal memory loaded...
Flash the controller test.hex and it flashes but fails verification,screen is black
#$&*swear
Erase device
Flash controllertest.hex. and it flashes fine and lcd screen shows "Internal memory required.
Flash InitialInternalMemory.hex Flashes but fails verification. LCD screen is black
Oh ok... You erase the chip, now I got it
I'm not used to AVR Studio.
Everytime I burn with avrdude, the chip gets erased by default automatically, but then again, I only burn bootloaders
It's a stumper, tried a breadboard with a blank 328P and programming by ISP from Atmel Studio, exact same issue. I did manage to find a sketch from about a year ago and it flashed fine on the RA board using ISP. Seems to be something with the newer Arduino 1.0.1. Will have to pick up a USB to TTL cord and program from the RA Arduino.
