Libraries 0.8.5.15(16)
Re: Libraries 0.8.5.15(16)
Good catch :)
Bryan wrote:I found the problem. If the LCD Timeout is set to 0, the menu's will not display with the joystick, changing it to anything other than 0 and it works fine. Perhaps the minimum setting in ReefClient memory settings needs to be >1 or the LCD locks.
Cheers
That is a good catch. I know that by default I don't give people the ability to change the LCD timeout unless you enable it. Also, the default setting is 600 seconds (5 minutes). I didn't think people would mess with it much at all. Anyways, suggestion/feedback is definitely noted.
