Function on and off at different times
mbertalha
Post by mbertalha »
Function on and off at different times.
Does anyone know if it is possible to turn an output on 40 minutes every 2 hours and remain so indefinitely?
The friend Paulo Hanashiro gave me a function that is used in metering pumps, but I miss a function of the pumps.
Sorry for my bad English.
Tanks guys.
Marcelo Bertalha
Re: Function on and off at different times
Well, wavemaker only does same cycle for on/off and dosingpumprepeat only does on cycle in seconds.
I guess we'll have to come up with a custom function.
rimai wrote:Well, wavemaker only does same cycle for on/off and dosingpumprepeat only does on cycle in seconds.
I've got some ideas for creating a function like this. Haven't written it yet, but it is something that is going to be added into the libraries.
I'll work up something for you later this weekend.
mbertalha
Post by mbertalha »
Thanks Curt.
I plan to use as a security system that does not happen to the reverse osmosis put more fresh water than necessary.
Every two hours the system releases a valve that feeds the aquarium for forty minutes. If the float if you have mechanical failure beyond the electronic system with the electromagnetic buoys you can count on the restriction of entry of water in the aquarium.
Att
Marcelo
