Client not showing data
wmhampton
Post by wmhampton »
So I have owned this controller for quiet some time and never been able to get this function to work. On the bottom it shows
"Listener: Running / Connected | Logger: Running | DB Version 2.2 | Dev Lib Version: x.x.x.xx |"
However no information is being sent to it...
So lost on what to do
Thank you for any help you can give
Re: Client not showing data
Can I see your code?
wmhampton
Post by wmhampton »
it is just the stock code that came with it, i never bothered to figure any of that out since it had all the functions i required.
Do you have an RA or RA+?
wmhampton
Post by wmhampton »
RA
It won't do it on the preloaded code.
You must enable the wifi framework to be able to communicate with the Client and the standard RA doesn't have wifi enabled on the preloaded code due to memory size constraints.
wmhampton
Post by wmhampton »
O boy!! How difficult is this to tackle?
Use the Wizard to create your own code and make sure to enable wifi.
Open Arduino and go to menu Tools->Reef Angel Wizard
wmhampton
Post by wmhampton »
Alright that was pretty simple to go through and figure out. However when I try to generate and upload it says an error has occurred please try again
