Forcing a date change
How to construct the url to force a time change through wifi directly, instead of Client?
Re: Forcing a date change
rimai wrote:How to construct the url to force a time change through wifi directly, instead of Client?
Here's how to update date/time without using the client:
http://CONTROLLER_IP:2000/dHHMM,MMDD,YY
The format is as follows:
  • HH - hours
  • MM - minutes
  • , - comma
  • MM - month
  • DD - day
  • , - comma
  • YY - year (since 2000)
Everything MUST be in 2 digit format. So single digits (like 8) must have a 0 prefix. Here's an example:
Set the date to August 8th, 2011 at 9:30am
http://CONTROLLER_IP:2000/d0930,0808,11
The controller will respond with OK and set the date/time on the controller. If there was an error, the controller will respond with ERR. The actual output will be like this:
Success -  <D>OK</D>
Error - <D>ERR</D>
NOTE: Type this in the URL box in your web browser to set the date/time.
The library is missing some code after line 536 on ReefAngel_Wifi.cpp
It needs this:
now();
RTC.set(now());
This is to save the values into the RTC chip. Otherwise the data goes right back to where it was on the next RTC sync or when rebooted.
Let me know if you need a pull request or this is sufficient.
rimai wrote:The library is missing some code after line 536 on ReefAngel_Wifi.cpp
It needs this:
now();
RTC.set(now());
Ok, thanks. I can add this in no problem. I've got a handful of changes in my dev branch that aren't reflected on github yet. :)
I'll make this change tonight.
