I had my RA hooked up and performing 2.5 hr long simulation yesterday when I was coding this for you and couldn't compile to verify errors.
Anyway, try this now:
// Autogenerated file by RAGen (v1.0.4.92), (09/01/2011 21:51)
// RA_090111_2151.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define SingleATOSetup
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
randomSeed(analogRead(0));
ReefAngel.PHMin=526;// 526=PH7.0
ReefAngel.PHMax=813;// 813=PH10.0
ReefAngel.FeedingModePorts = B10000000;
ReefAngel.OverheatShutoffPorts = B01000000;
ReefAngel.Relay.On(Port8);
ReefAngel.Timer[1].SetInterval(random(10,150));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port4);
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.Relay.Toggle(Port4);
ReefAngel.StandardFan(Port6);
// Have PWM on from 12p to 9:30p, with gradual 150 minute ramp up and 180 down for actinic, and 120 minute ramp up and down for daylight starting at given times
// From 12pm to 1pm, actinic will slowly ramp up from 10% to 100%, and from 12:30p to 2p, daylight will slowly ramp up from 10% to 50%
// From 8:30p to 9:30p, actinic will slowly ramp down from 100% to 10%, and from 7p to 8:30p daylight will slowly ramp down from 50% to 10%
if (hour()<16)
if (hour()<12)
ActinicPWMValue=MoonPhase();
ActinicPWMValue=PWMSlope(12,0,21,30,10,100,150,ReefAngel.PWM.GetActinicValue());
if (hour()<21)
ActinicPWMValue=PWMSlope(12,0,21,30,10,100,180,ReefAngel.PWM.GetActinicValue());
else if (hour()==21 && minute()<=30)
DaylightPWMValue=PWMSlope(12,30,20,30,10,50,120,ReefAngel.PWM.GetDaylightValue());
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 8
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
// In this example, start could be after 11:30am
#define Start_Cloud_After NumMins(15,00)
// In this example, end could before 6:00pm
#define End_Cloud_Before NumMins(18,00)
#define Lightning_Change_per_Cloud 10
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
byte MoonPhase()
int m,d,y;
int yy,mm;
long K1,K2,K3,J,V;
byte PWMvalue;
m=month();
d=day();
y=year();
yy=y-((12-m)/10);
mm=m+9;
if (mm>=12) mm-=12;
K1=365.25*(yy+4712);
K2=30.6*mm+.5;
K3=int(int((yy/100)+49)*.75)-38;
J=K1+K2+d+59-K3;
V=(J-2451550.1)/0.29530588853;
V-=int(V/100)*100;
V=abs(V-50);
PWMvalue=4*abs(50-V); // 5.12=100% 4=~80%
//pinMode(lowATOPin,OUTPUT);
return (PWMvalue*100)/255;
