PMSLOPE QUESTION
divingdon
Re: PMSLOPE QUESTION
Post by divingdon »
The 6 Meanwell's are connected to 2 seperated timers on 2 different power strips what is plugged in on RA outlet 7 is the DC power supply which supplys the PWM volatage.
No I dont use the PC logging function I just put it into the sketch was I was having problems making the client 2.2 work correctly but that problem wasn't the fix so I will remove that line.
Any ideas why the timers maybe functioning incorrectly??
Try this code:
// Autogenerated file by RAGen (v1.0.4.92), (08/25/2011 17:16)
// RA_082511_1716.pde
 #define wifi
 #define StandardLightSetup
 #define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
ReefAngel_TimerClass ParamTimer;
//Give labels to your PWM channels
#define WhitePWM1 0
#define BluePWM1 1
#define WhitePWM2 2
#define BluePWM2 3
#define WhitePWM3 4
#define BluePWM3 5
byte PWMChannel[]={
  0,0,0,0,0,0};
  // Initialize and start the Parameter timer
  ParamTimer.SetInterval(15); // set interval to 15 seconds
  ParamTimer.Start();
  ReefAngel.FeedingModePorts = B00111111;
  ReefAngel.WaterChangePorts = B00111111;
  ReefAngel.OverheatShutoffPorts = B00110000;
  ReefAngel.LightsOnPorts = B11000100;
  ReefAngel.Relay.On(Port1);
  ReefAngel.Relay.On(Port2);
  ReefAngel.Relay.On(Port3);
  // Specific functions
  ReefAngel.StandardFan(Port4);
  ReefAngel.StandardHeater(Port5);
  // Setup relay 7 to turn on at 06:00aM and off at 10:15AM
  ReefAngel.StandardLights(7,06,45,22,00);
  ReefAngel.Relay.Write(); //Writes the value of RelayData to the RelayBox
  // Setup relay 8 to turn on at 18:00PM and off at 00:00AM
  ReefAngel.StandardLights(8,18,0,00,00);
  //This section calculates the slope
  //calculate slope for 0 to 50% starting at 12:30pm with duration of 60min, then from 50% to 0 from 17:00pm with duration of 60min
  PWMChannel[WhitePWM1]=2.55*PWMSlope(06,45,21,00,14,35,60,PWMChannel[WhitePWM1]);
  PWMChannel[BluePWM1]=2.55*PWMSlope(06,45,21,15,14,40,60,PWMChannel[BluePWM1]);
  PWMChannel[WhitePWM2]=2.55*PWMSlope(06,46,21,00,14,35,60,PWMChannel[WhitePWM2]);
  PWMChannel[BluePWM2]=2.55*PWMSlope(06,46,22,00,14,40,60,PWMChannel[BluePWM2]);
  PWMChannel[WhitePWM3]=2.55*PWMSlope(06,47,21,00,14,35,60,PWMChannel[WhitePWM3]);
  PWMChannel[BluePWM3]=2.55*PWMSlope(06,47,21,15,14,40,60, PWMChannel[BluePWM3]);
  // this section sends the data to the PWM expansion module
  PWMExpansion(WhitePWM1,PWMChannel[WhitePWM1]);
  PWMExpansion(BluePWM1,PWMChannel[BluePWM1]);
  PWMExpansion(WhitePWM2,PWMChannel[WhitePWM2]);
  PWMExpansion(BluePWM2,PWMChannel[BluePWM2]);
  PWMExpansion(WhitePWM3,PWMChannel[WhitePWM3]);
  PWMExpansion(BluePWM3,PWMChannel[BluePWM3]);
void PWMExpansion(byte cmd, byte data)
  Wire.beginTransmission(2); // transmit to device #2
  Wire.send('$'); // sends $
  Wire.send(cmd); // sends a value
  Wire.send(data); // sends 255
  Wire.endTransmission(); // stop transmitting}
I think your problem was this:
ReefAngel.StandardLights(7,06,0,22,15);
This line turns on at 6:00AM and off at 10:15PM
I think 14% still doesn't cut off your meanwells, so as long as the drivers have power, they were lighting up at 14%.
I change the above code to match the same as your PWMSlope schedule.
divingdon
Post by divingdon »
thanks I just load that sketch will 1 change I changed the starting PWM voltage from 1.4 to .8 to make sure the LEDs go off and I notice after loading that the red status light is staying lite??
any ideas
Don't see how the red status would stay on, but I did forget to remove some stuff. I don't know where I had my mind.
Updated:
#define wifi
#define SIMPLE_MENU
#define WhitePWM1 0
#define BluePWM1 1
#define WhitePWM2 2
#define BluePWM2 3
#define WhitePWM3 4
#define BluePWM3 5
byte PWMChannel[]={
  0,0,0,0,0,0};
divingdon
Post by divingdon »
the whites just shut off @ 2019 just under 30 mins early
divingdon
Post by divingdon »
Sorry posted before I saw your new sketch I will download and try that..
divingdon
Post by divingdon »
loaded your sketch white LEDs still off and Status LED stilled turned on???
I think they are just going below the cutoff.
You better off leaving it above the cutoff and leaving it to be totally off when the relay turns the drivers off
Do you have overheat setup on your features file?
I think that's the reason you are getting status led.
divingdon
Post by divingdon »
The status light issues is fixed but since i loaded the sketch you fixed for me I cant use the client software it doesn't connect. Did I do something wrong or is some code missing??
Can you post your features file?
divingdon
Post by divingdon »
// AutoGenerated file by RAGen (v1.0.4.92), (08/25/2011 17:53)
* Copyright 2010 / Curt Binder
* Licensed under the Apache License, Version 2.0 (the "License")
#define wifi
#define SIMPLE_MENU
that was all of it
Everything seems correct.
Maybe the wifi got a different ip address while doing all the changes?
divingdon
Post by divingdon »
IP was the same as before. Rebooted everything and now it works.
Thanks for your help.
Have you tried the optiboot upgrade with the homemade cable. I have one and I'm waiting to do the update.
