Sketch Too Large
jcm2m9
Sketch Too Large
Post by jcm2m9 »
I recently purchased another relay box and two dosing pumps and am trying to generate a new sketch.
I am just over on size and can not figure out how to reduce it.
Any suggestions?
    ReefAngel.FeedingModePortsE[0] = Port3Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardHeater( Port4 );
    ReefAngel.DosingPumpRepeat1( Port5 );
    ReefAngel.DosingPumpRepeat2( Port6 );
    ReefAngel.SingleATOLow( Port7 );
    ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port1 ) );
    ReefAngel.Relay.DelayedOn( Box1_Port1 );
    ReefAngel.StandardFan( Box1_Port4 );
    ReefAngel.MoonLights( Box1_Port5 );
    ReefAngel.Portal( "jcm2m9" );
    int x,y;
    // Relay Expansion
Re: Sketch Too Large
Custom main takes a ton of space. I've reduced my custom main to the bare minimum.
jcm2m9
Post by jcm2m9 »
I as able to reduce the sketch size by removing the graph and date/time from the display.
I now need to find some jumpers for my head unit. I did not find them included with my shipment of the expansion relay.
Old IDE hardrives will have one as well as old IDE cdroms
