Hi Roberto:
Afraid you may be right <sigh>. Do you mind posting the sketch you used. I think I might know what the problem is in AVRStudio, but want to make sure I have the right sketch code first.
Temp sensor problems
Re: Temp sensor problems
-=Bryan=-
I actually used the standard libraries, but here is the sketch.
- LibraryTest.pde
- (2.18 KiB) Downloaded 413 times
I think it might be one of the compiler optimization flags I am using in AVRStudio that could be causing the problem. They both use AVR-GCC so can't see why it would not work other than my addition of additional flags.
-=Bryan=-
Yup, that was what it was, one of the optimization flags I was using, just not sure which one though, will be a process of elimination. Used the standard flags that Arduino uses and it worked, albeit a larger hex size.
-=Bryan=-
