Wave patterns
Re: Wave patterns
It's in the original post
Each function has a different unit. Short Pulse and NTM are milliseconds, but Long Pulse is seconds.
Also, your code is missing one parameter. It's supposed to be 4 total.
Check the original post.
Re: Wave patterns
Sorry Roberto. Like I said I'm a complete noob to coding.
It looks like I left out the PulseMinSpeed or PulseMaxSpeed.
So would it be like this?
ReefAngel.PWM.SetDaylight( LongPulseMode(45,70,10,true));
Re: Wave patterns
Thanks for making me figure it out.
Again "Teach a man to fish".
Re: Wave patterns
So I've scanned throughout the last 5 or so pages and didn't see it. Is there ant way we can get Lagoon mode add to the wave patterns?
Dustin
Dustin
Re: Wave patterns
Well, Lagoon is nothing more than reefcrest with a very close min and max range.
Re: Wave patterns
Ok I got most everything setup last night.
There's only a couple of things I need to tackle still, but the first and what seems to be the easiest is hooking up and coding the WP40.
I know all the wave patterns are on the first page (Thank Roberto), but can someone equate them to the different modes on the WP40?
H: High, constant, non-variable flow (13,000 LPH)
L: Low, constant, non-variable flow at a third of the speed (4,300 LPH)
W1: Short pulses which, when timed correctly will create a back and forth motion and form a gentle standing wave in your tank. Adjust the controller to change the speed of the pulses and vary the size of the wave according to your tank.
W2 & W3: Pump gradually speeds up and slows down incrementally to create a varied flow pattern. Adjustable to form the wave best suited to your tank.
Else: Reef Stream Mode, a mixed, changing pattern that creates a random flow cycle similar to what you would find in a natural reef.
I currently use W1 on a slow speed 16-18V and a medium wave length.
Re: Wave patterns
Could I just ask as I may be looking at this a bit to simplistically:
I have 2x wp40's that I want to connect to my light ports and for example I want a long pulse minimum power at 10% maximum at 50 lasting for 20 seconds each anti-sync I would enter the below into my loop?
ReefAngel.PWM.SetDaylight( LongPulseMode(10,50,20,true))
ReefAngel.PWM.SetActinic( LongPulseMode(10,50,20,false))
Dave
Dave
Re: Wave patterns
I'm just getting into coding and by no means am an expert, but this looks correct.
The criteria for Long Pulse is...
Long Pulse
PulseMinSpeed - % for minimal speed
PulseMaxSpeed - % for maximum speed
PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
Long Pulse
Re: Wave patterns
Hi SacohenSacohen wrote:I'm just getting into coding and by no means am an expert, but this looks correct.
Long Pulse
Its how I see it as well; I should thank you really as you have been asking all the questions I would have put
We will see what the masters of the "black art" say, I hope we are both not mistaken
Thanks again
Dave
Re: Wave patterns
Yeap, that's all you needcoolbird wrote:Could I just ask as I may be looking at this a bit to simplistically:
Dave
Re: Wave patterns
You mean I got something right Roberto I will try not to make a habit out of it,,,,,,,thanksrimai wrote:Yeap, that's all you needcoolbird wrote:Could I just ask as I may be looking at this a bit to simplistically:
Dave
Re: Wave patterns
Well... Almost there.... You just missed the ; at the end of the 2 lines, but the idea was there and I consider this just a typo....
Re: Wave patterns
I still forget parens, semicolons, braces all the time...thats what compiler errors are for
Re: Wave patterns
Nope Roberto no typo I had missed them off serves me right for being smug with my minor success.rimai wrote:Well... Almost there.... You just missed the ; at the end of the 2 lines, but the idea was there and I consider this just a typo....
Re: Wave patterns
Hey folks, not trying to hijack your thread here. I need a bit of help with my controllable pump... Still trying to figure out if it's doable and if so how... I can't post links or send private messages I'm such a noob, but if you search for 'Help to connect a certain controllable pump to my ATO DWM' you will find it.
Re: Wave patterns
I seem to be missing something here I am using the lines below but I was trying to get the pumps to alternate and as I understand it to do this you need one on false and the other on true (or have I got this wrong,,,again)coolbird wrote:You mean I got something right Roberto I will try not to make a habit out of it,,,,,,,thanksrimai wrote:Yeap, that's all you needcoolbird wrote:Could I just ask as I may be looking at this a bit to simplistically:
Dave
Doesn't seem to matter whether I have them false and true or both on true they seem to be coming on for 20 seconds at the set percentage then both dropping back to the reduced powerthen after 20 seconds back up to 30% again!!
ReefAngel.PWM.SetDaylight( LongPulseMode(10,30,20,true));
ReefAngel.PWM.SetActinic( LongPulseMode(10,30,20,false));
Any advice would be welcome.
Dave
Re: Wave patterns
Yes, your code looks correct.
What do you see in the screen for AP/DP?? Are they alternating?
Re: Wave patterns
On the ra screen its just showing the both solid at 30, not changing at all either of them!!rimai wrote:Yes, your code looks correct.
Edit:
When you run through the wizard am i supposed to change anything in the light settings?
Re: Wave patterns
Oh, I know now what is happening.
I don't think the pump can go much lower than 30%.
So, anything lower than 30% is capped at 30%.
If people that have been using this pump can confirm that the pump can indeed go lower than 30%, please let me know and I'll certainly change the libraries.
Re: Wave patterns
Can they go to zero then?
Re: Wave patterns
Not with this function.
We can code it differently to get the same results in order to go down to zero.
Re: Wave patterns
Thanks. For what I have in mind that would be very usefulrimai wrote:Not with this function.
Re: Wave patterns
Use this instead then:
byte Jebao=(now()%(20*2)<20?0:30);
ReefAngel.PWM.SetActinic(Jebao);
ReefAngel.PWM.SetDaylight(Jebao==0?30:0);
Re: Wave patterns
Sorry Roberto how does that code work the parameters, just so I can tweak itrimai wrote:Use this instead then:Code: Select all
byte Jebao=(now()%(20*2)<20?0:30); ReefAngel.PWM.SetActinic(Jebao); ReefAngel.PWM.SetDaylight(Jebao==0?30:0);
Dave
Re: Wave patterns
This is easier:
Change what's in the define section
#define JebaoDuration 20
#define JebaoMin 0
#define JebaoMax 30
byte Jebao=(now()%(JebaoDuration*2)<JebaoDuration?JebaoMin:JebaoMax);
ReefAngel.PWM.SetDaylight(Jebao==JebaoMin?JebaoMax:JebaoMin);
Re: Wave patterns
And what do I do about the lines I have already put in? Sorry its national daft question day in the UKrimai wrote:This is easier:Change what's in the define sectionCode: Select all
#define JebaoDuration 20 #define JebaoMin 0 #define JebaoMax 30 byte Jebao=(now()%(JebaoDuration*2)<JebaoDuration?JebaoMin:JebaoMax); ReefAngel.PWM.SetActinic(Jebao); ReefAngel.PWM.SetDaylight(Jebao==JebaoMin?JebaoMax:JebaoMin);
Re: Wave patterns
OK will give it a try and let you knowrimai wrote:Remove them and replace with the post above
Dave
Re: Wave patterns
Thanks for contributing!!!
If I don't hear anyone else, I'll lower it to 25 on the next update.
