Wave patterns
Re: Wave patterns
But I'm using those functions with my Vortech or someone may want to use it with leds or something we havent tbought of. Plus the thresholds on some jaebo is 20 something.
Re: Wave patterns
Thats why doing it in the class where you can persistently define what is the threshold and doing the remapping there instead of in the global generic function.
AlanM
Re: Wave patterns
Post by AlanM »
Ah, got it. I didn't realize that people were directly driving their vortech speeds with the RA. I figured you'd just tell the WES controller to flip you to a different mode with given parameters.
Re: Wave patterns
I could but i could also use one of the RA modes or custom functions like ElseMode and one the bhazard did that I setup as custom functions. I can also do each channel individually letting me change which pump is sync anti sync on the fly. I also added an offset so I can change the power level of the anti sync pump.
AlanM
Re: Wave patterns
Post by AlanM »
OK, so if I added in a Threshold value in DCPump.cpp (and .h of course) for each possible pump, Daylight, Actinic, LowATO, 6 Expansions, and 16 extra Expansions, I would have to look for those thresholds in the ReefAngel.cpp and constrain what the calls to the wave modes give out when calling the SetDaylight, SetChannel, etc. methods. I'd probably add a function in Globals that returns 0 or threshold->max when given a value and just call that one each time.
I understand that the values set in DCPump.DaylightChannnel are booleans that are Sync or AntiSync, so 0 or 1, and I see that each call in ReefAngel.cpp subtracts one from those values, what is the -1 for in those calls to wave modes?
Re: Wave patterns
I think because sync is 1 and anti sync is 2 and therefore the -1 brings it to 0 and 1 which correspond to true/false
Btw roberto not sure bools actually save any space as i think arduino stores bools as a byte...
AlanM
Re: Wave patterns
Post by AlanM »
I submitted a pull request to include my PWM profile and also ElseMode since lots of people are using it. However, I see that in the ReefAngel.cpp there is a switch statement that figures out the different modes set in the DCPump classes. Where are those modes defined? I can't find them. In the process of prowling more code I'm finding more dependencies in different places.
Re: Wave patterns
The modes are defined in the Globals.h
The case statements match the "Vortech" modes that are listed in the Portal. For any new modes, you'd use the "Custom" mode that's defined in the portal and then handle the condition in your INO.
AlanM
Re: Wave patterns
Post by AlanM »
Oh really? OK. I get it, I think.
Sounds like adding ElseMode to the DCPump class is a bit more complicated than just including it in that switch/case statement because it wouldn't work to just make a #define ElseMode 7 line in there. I'd leave ElseMode out of my copy of ReefAngel.cpp and DCPump.Mode until figuring it out.
Re: Wave patterns
Yeah, find the modes that are defined in Globals.h because the first available may not be until after 11 or 12... I think there are some that apply to the Radions. Not sure that's really a conflict. I dont' think there's anythign that would prevent it from being added into the code, except that if we wanted to advertise the support for it, it would need to be added in the portal. That's really a chicken and the egg discussion though... but if you build it they will come.. so they say ;)
AlanM
Re: Wave patterns
Post by AlanM »
OK. Can look in to adding it there some more. My pull requests are in and seem to be fairly simple and compile for me, at least. 8)
Rodasphoto
Re: Wave patterns
Post by Rodasphoto »
subscribing for later use
Ademster
Re: Wave patterns
Post by Ademster »
how do I code all of the different pump options to cycle randomly. but also during feed mode to drop to 15 % .
running a wp-25 will be connected to the relay box dimming port.
Adam
58 Gal
Re: Wave patterns
Ademster wrote:how do I code all of the different pump options to cycle randomly. but also during feed mode to drop to 15 % .
Take a look at the code in my signature.
lnevo helped me with exactly what I think you want to do.
The only difference is I'm using 2 pumps on Anti-Sync rather than 1 pump.
I have my drop to 0% during feed and 30% at night.
I think 15% is to low for the pumps. The Jebao have a minimum speed and when they go below that they will not ramp back up unless you pull the power to them and plug them back in.
I've found the WP-40 to be 25% and the WP-25 to be 30%.
Ademster
Re: Wave patterns
Post by Ademster »
Adam
58 Gal
saf1
Re: Wave patterns
Post by saf1 »
Older thread I know but had a quick question or two after reading it. I'm considering picking up two Jebao wave makers but not sure if the model is correct or will work with the Jebao/Speedwave cable offered here.
It seems there is the standard WP series and now a RW series. Which version does the reef angel controller support? I just wanted to be sure so I order the correct one. I have two open ports I believe on my expansion or at least one there and then the original on the relay box that isn't used.
One cable per power head I'm assuming? I have a 40 breeder that has 4 power heads in there now and I'd like to clean things up a bit so wanted to run a pair and see how this wave pattern code works out. After reading it, it looks pretty neat.
Thanks for any help and or assistance. I'm guessing the WP 40's may be ok or just buy the larger one, WP 60, and re-use when I finally get a large tank. I am hoping the cable works with the RW series since it seems they do not clog as bad and have a few more settings.
Re: Wave patterns
I have not seen the RW series personally, but I believe it is the same connection as the WP pumps.
Yes 1 cable per power head without some modifications.
2 60's in a 40 gallon is way to much power.
Go with 2 40's.
I actually had a 40 and 25 running in my 55 gallon and even then they were at 50% speed.
saf1
Re: Wave patterns
Post by saf1 »
Sacohen wrote:I have not seen the RW series personally, but I believe it is the same connection as the WP pumps.
Go with 2 40's.
Thanks for the information. Yeah, I figured they would be too high and would need to be turned down. I was thinking, incorrectly it sounds like, that I could just power them down then reuse in a larger tank later. From what you are saying in regards to their power two 40's it is. Plus I will save a few bucks to spend on the cables.
Thank you again.
Re: Wave patterns
Personally it think the 60's even powered down will be to strong for a 40 gallon.
The Jebao WP pumps had an issue that they would lock up if they went below a certain percentage.
With the WP-40's it seemed to be 30% and with the WP 25's it seemed to be 25% (or I have that reversed).
Maybe I misunderstood you or you misunderstood me. but you need 1 Jebao cable for each of the pumps.
It may be able to be done with 1 cable, but you would have to modify the cable quite a bit and it wouldn't be worth it.
saf1
Re: Wave patterns
Post by saf1 »
Sacohen wrote:Personally it think the 60's even powered down will be to strong for a 40 gallon.
Nope, you explained it perfectly and I'll be ordering two cables ;) You also helped me with regards to the power. So al is well and thank you again.
Re: Wave patterns
No problem.
saf1
Re: Wave patterns
Post by saf1 »
Picked up two RW-4's for the 40 gallon breeder which is made up mostly of soft corals and 3 rose bubble tip anemones. My order for two cables came in so I just finished connecting everything and adding some basic code from a few pages back that cycled through reef crest and nutrient export modes. Uploaded the code and saw a blast of water movement then nothing.
Probably have my code in the wrong place I'm guessing because they shot on for a second then nothing. I'll need to clean this up and label the ports on the relay box since it is getting messy. Side note - I just added the wireless adapter and it works great. Question - do I have to disconnect the wireless adapter every time I want to upload new code?
Code:
ReefAngel.AddWifi();
ReefAngel.StandardLights( Port2,9,0,21,0 );
ReefAngel.StandardLights( Port4,9,0,21,0 ); // LED fans
ReefAngel.WavemakerRandom(Port5,60,300);
// ReefAngel.WavemakerRandom(Port5,120,600);
// ReefAngel.WavemakerRandom(Port6,120,600);
// Turn Port5 on/off random cycles that lasts from 25 to 60 secs
// ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
// ReefAngel.Relay.Set(Port8,!ReefAngel.Relay.Status(Port7));
// This will turn off both relays at a set time
if (hour()>=20 || hour()<10)
ReefAngel.Relay.Off(Port5); // large power head
ReefAngel.Relay.Off(Port6); // large power head
ReefAngel.Relay.Off(Port4); // LED fans
ReefAngel.Relay.On(Port7); // Small power head for night
ReefAngel.Relay.On(Port8); // Small power head for night
ReefAngel.Relay.Off(Port7);
ReefAngel.Relay.Off(Port8);
// Channel 0 (1000mA max) - 5 Neutral White
// Channel 1 (1000mA max) - 6 Royal Blue + 5 Blue
// Channel 2 (700mA max) - 12 Lime
// Channel 3 (700mA max) - 5 Violet UV + 4 Deep Red (660nm)
ReefAngel.PWM.SetChannel( 0, PWMParabola(10,0,20,0,0,65,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(10,0,20,0,0,75,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(10,0,20,0,0,65,0) );
ReefAngel.PWM.SetChannel( 3, PWMParabola(10,0,20,0,0,65,0) );
// Testing wave pumps
if (hour()>=16 && hour()<18)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(77,90,3000,false) ); // Nutrient Transport on anti-sync mode
else if (hour()>=18 && hour()<16)
ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) ); // ReefCrest at 50% + - 20 on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(50,20,false) ); // ReefCrest at 50% + - 20 on anti-sync mode
ReefAngel.Portal( "saf1" );
ReefAngel.DDNS( "saf1-dns.myreefangel.com" ); // Your DDNS is saf1-dns.myreefangel.com
Re: Wave patterns
I'm not sure about the code, but a quick look it seems right, except it looks like you have the wave mode on ports 5 & 6 and are also using the DC Pump code.
If you don't have the Bluetooth module you will need to unplug the WiFi module every time you want to update your code.
saf1
Re: Wave patterns
Post by saf1 »
Yeah, that is odd. Not really sure at this point since I have cruddy notes and they don't look that great in the sketch either :( I just re-ran the wizard and it produced something that has at least one side working but not sure if this is right either so I'll need to continue to try. Also those little things can put out some water movement. I accidently had 90 percent I guess and everything was moving around way too much. Caught it and reset to 50 and everything seems pretty happy.
Originally on my power / relay box it was like this. Daylight and Actinic channels not used.
Plug 1 - skimmer (always on, off for feeding)
Plug 2 - Power supply for LED's - set time on/off
Plug 3 - NA
Plug 4 - LED heat sink fans - come on once LED's start up
Plug 5 - large power head powers on at 10 am until 8 pm
Plug 6 - large power head powers on at 10 am until 8 pm
Plug 7 - small power heads only coming on at 10 PM
Plug 8 - small power heads only coming on at 10 PM
The goal is to remove the koralia power heads and just use the RW-4's if I can get them to work together or educated is how I think they work :) I am reading it as reef crest daylight is set to sync with actinic set to antisync. So at some time - not sure when, one side shuts down and the other kicks in. Sort of simulating high/low tide. I just don't see that time window or cut off.
New code:
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port2,9,0,21,0 ); // power to LED power supply
// ReefAngel.WavemakerRandom( Port5,5,90 ); // Not sure what these are for now
// ReefAngel.WavemakerRandom( Port6,5,90 ); // Not sure what these are for now
// ReefAngel.StandardLights( Port7,9,0,21,0 );
// ReefAngel.StandardLights( Port8,9,0,21,0 );
ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
// ReefAngel.DCPump.ExpansionChannel[0] = None;
// ReefAngel.DCPump.ExpansionChannel[1] = None;
// ReefAngel.DCPump.ExpansionChannel[2] = None;
// ReefAngel.DCPump.ExpansionChannel[3] = None;
// ReefAngel.DCPump.ExpansionChannel[4] = None;
// ReefAngel.DCPump.ExpansionChannel[5] = None;
ReefAngel.DDNS( "saf1-dns.myreefangel.com" ); // Your DDNS is saf1-saf1-dns.myreefangel.com.myreefangel.com
Re: Wave patterns
That's not how ReefCrest works. ReefCrest slowly meanders between the midline (50 in your case) by +/- the offset (10 here). When the sync goes up, the antisync goes down. So they both should be on constantly, going between 40 and 60.
saf1
Re: Wave patterns
Post by saf1 »
cosmith71 wrote:That's not how ReefCrest works. ReefCrest slowly meanders between the midline (50 in your case) by +/- the offset (10 here). When the sync goes up, the antisync goes down. So they both should be on constantly, going between 40 and 60.
Ok, that makes sense and also what I see although I thought I saw higher than 60 on one side. I'll add a if statement to get them to swap who is anti then.
Thanks, appreciate you taking time to explain it.
Re: Wave patterns
You can use tide.IsIncoming() it might be isIncoming as your condition for swapping the channels
saf1
Re: Wave patterns
Post by saf1 »
Ok, thanks. I'll see if I can find an example of that. Right now I have the standard reef crest to go to 25 when the lights go off (9 PM). Then standard power when them come on again at 9 AM. I don't know what mode actually does what so I'm just using reef crest for now but would like to get the sides to alternate.
Does it make more sense to change flow patterns or just use one?
if (hour()>=21 || hour()<9)
// Sleep mode - slow things down
ReefAngel.DCPump.SetMode( ReefCrest,25,10 );
// Normal power
saf1
Re: Wave patterns
Post by saf1 »
Ok, found the compile error. Case sensitive :) Was using uppercase T instead of lowercase t when calling tide. Not sure if this is the right way to set it up but the tide function has the if statement to set PWM sync or anti sync. Then I let my main run window use full power or reduce after lights out.
Thanks.
-scott
#include <Tide.h>  // testing for tide control
Tide tide;  // testing for tide control
 ReefAngel.Relay.On( Port1 );  // skimmer
 // ReefAngel.Relay.On( Port4 );  // LED Fans
 ReefAngel.Relay.On( Port5 );  // RW 4 left side facing tank
 ReefAngel.Relay.On( Port6 );  // RW 4 right side facing tank
 ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,21,0,0,65,0) );
 ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,21,0,0,75,0) );
 ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,21,0,0,65,0) );
 ReefAngel.PWM.SetChannel( 3, PWMParabola(9,0,21,0,0,65,0) );
// ReefAngel.DCPump.SetMode( ReefCrest,55,10 );
// ReefAngel.DCPump.DaylightChannel = Sync;
// ReefAngel.DCPump.ActinicChannel = AntiSync;
// Testing tidal function
if (tide.isIncoming()) {
else {
// Normal power
Re: Wave patterns
Thats perfect! Now if you want to use the tide mode more you can set the parameters for the tide speed to fluctuate through the day and the variation would be based on the MoonPhase() so where you are calling SetMode and giving the ReefCrest speed you could get the speed from the tide class. Also the tide class kind of has a built in night mode at least how I have it set
