ok Im a little lost. have had my WP40 cable for about a week and thought I would try to get my Jabao pump set up.
If I understand it correctly all I have to do is add a code from page 1, of this topic, between the lines "Place your custom code below/above here" on my sketch.
I can add this code from page 2 and it works fine:
byte random_speed=35;
if (now()%5==1) random_speed=random(35,70);
ReefAngel.PWM.SetDaylight( LongPulseMode(random_speed,70,5,true));
But if I add lets say the "Reefcrest" code from page 1:
byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
static unsigned long lastwavemillis=millis();
static int newspeed=WaveSpeed;
if ((millis()-lastwavemillis) > 5000)
if (random(100)<50) newspeed--; else newspeed++;
newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
newspeed=constrain(newspeed,0,100);
if (PulseSync)
return newspeed;
return WaveSpeed-(newspeed-WaveSpeed);
I get the following error from Arduino: a function-definition is not allowed here before{token
Do I need to do something to the code before adding it to my sketch?
Thanks for any help
