Re: Wave patterns
Posted: Tue Apr 22, 2014 12:51 pm
OK. Can look in to adding it there some more. My pull requests are in and seem to be fairly simple and compile for me, at least. 8)
http://forum.reefangel.com/
Take a look at the code in my signature.Ademster wrote:how do I code all of the different pump options to cycle randomly. but also during feed mode to drop to 15 % .
running a wp-25 will be connected to the relay box dimming port.
Thanks for the information. Yeah, I figured they would be too high and would need to be turned down. I was thinking, incorrectly it sounds like, that I could just power them down then reuse in a larger tank later. From what you are saying in regards to their power two 40's it is. Plus I will save a few bucks to spend on the cables.Sacohen wrote:I have not seen the RW series personally, but I believe it is the same connection as the WP pumps.
Yes 1 cable per power head without some modifications.
2 60's in a 40 gallon is way to much power.
Go with 2 40's.
I actually had a 40 and 25 running in my 55 gallon and even then they were at 50% speed.
Nope, you explained it perfectly and I'll be ordering two cables You also helped me with regards to the power. So al is well and thank you again.Sacohen wrote:Personally it think the 60's even powered down will be to strong for a 40 gallon.
The Jebao WP pumps had an issue that they would lock up if they went below a certain percentage.
With the WP-40's it seemed to be 30% and with the WP 25's it seemed to be 25% (or I have that reversed).
Maybe I misunderstood you or you misunderstood me. but you need 1 Jebao cable for each of the pumps.
It may be able to be done with 1 cable, but you would have to modify the cable quite a bit and it wouldn't be worth it.
Ok, that makes sense and also what I see although I thought I saw higher than 60 on one side. I'll add a if statement to get them to swap who is anti then.cosmith71 wrote:That's not how ReefCrest works. ReefCrest slowly meanders between the midline (50 in your case) by +/- the offset (10 here). When the sync goes up, the antisync goes down. So they both should be on constantly, going between 40 and 60.
#include <Tide.h> // testing for tide control
Tide tide; // testing for tide control
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit;
ReefAngel.Relay.On( Port1 ); // skimmer
// ReefAngel.Relay.On( Port4 ); // LED Fans
ReefAngel.Relay.On( Port5 ); // RW 4 left side facing tank
ReefAngel.Relay.On( Port6 ); // RW 4 right side facing tank
ReefAngel.StandardLights( Port2,9,0,21,0 ); // power to LED power supply
ReefAngel.StandardLights( Port4,9,0,21,0 ); // LED fans
// ReefAngel.WavemakerRandom( Port5,5,90 ); // Not sure what these are for now
// ReefAngel.WavemakerRandom( Port6,5,90 ); // Not sure what these are for now
// ReefAngel.StandardLights( Port7,9,0,21,0 );
// ReefAngel.StandardLights( Port8,9,0,21,0 );
// Channel 0 (1000mA max) - 5 Neutral White
// Channel 1 (1000mA max) - 6 Royal Blue + 5 Blue
// Channel 2 (700mA max) - 12 Lime
// Channel 3 (700mA max) - 5 Violet UV + 4 Deep Red (660nm)
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,21,0,0,65,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,21,0,0,75,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,21,0,0,65,0) );
ReefAngel.PWM.SetChannel( 3, PWMParabola(9,0,21,0,0,65,0) );
// ReefAngel.DCPump.SetMode( ReefCrest,55,10 );
// ReefAngel.DCPump.DaylightChannel = Sync;
// ReefAngel.DCPump.ActinicChannel = AntiSync;
// Testing tidal function
if (tide.isIncoming()) {
else {
ReefAngel.DCPump.DaylightChannel = AntiSync;
// ReefAngel.DCPump.ExpansionChannel[0] = None;
// ReefAngel.DCPump.ExpansionChannel[1] = None;
// ReefAngel.DCPump.ExpansionChannel[2] = None;
// ReefAngel.DCPump.ExpansionChannel[3] = None;
// ReefAngel.DCPump.ExpansionChannel[4] = None;
// ReefAngel.DCPump.ExpansionChannel[5] = None;
if (hour()>=21 || hour()<9)
// Sleep mode - slow things down
ReefAngel.DCPump.SetMode( ReefCrest,25,10 );
// Normal power
ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
ReefAngel.Portal( "saf1" );
ReefAngel.DDNS( "saf1-dns.myreefangel.com" ); // Your DDNS is saf1-saf1-dns.myreefangel.com.myreefangel.com
Cool, thanks for the information because that is what I'm actually looking for. I know I am only going to get "so" much out of the R4's in a 40 gallon breeder but it is more about learning how this works, the corals, and overall look. I like what they are doing with just this basic routine and imagine the rose bubble tips will love one I get some variation in there.lnevo wrote:Thats perfect! Now if you want to use the tide mode more you can set the parameters for the tide speed to fluctuate through the day and the variation would be based on the MoonPhase() so where you are calling SetMode and giving the ReefCrest speed you could get the speed from the tide class. Also the tide class kind of has a built in night mode at least how I have it set
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,21,0,0,90,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,21,0,0,55,0) );
else {
// Full power to run during the day with lights on
// Start at 9 AM run through 9 PM
ReefAngel.DCPump.SetMode( TidalSwell,80,20 );
