Wizard keeps giving error
Toolboy
Post by Toolboy »
Hi
Im trying to add my new PWM unit
Ive compiled my code with the wizard and when I say upload I keep getting an upload error
Below is my code
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
InternalMemory.OverheatTemp_write( 270 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,250,255 );
ReefAngel.StandardFan( Port3,250,260 );
ReefAngel.StandardFan( Port4,250,260 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(9,0,0,0,15,100,60,15) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(13,0,0,0,15,100,60,15) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(13,0,0,0,15,100,60,15) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(13,0,0,0,15,100,60,15) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(13,0,0,0,15,100,60,15) );
ReefAngel.PWM.SetChannel( 5, PWMSlope(13,0,0,0,15,100,60,15) );
ReefAngel.Portal( "toolboysa" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
This is from status block
Watchdog Timer
Version Menu
Dimming Expansion Module
Dimming Signal
Wifi Attachment
Custom Main Screen
Simple Menu
Binary sketch size: 28,790 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\Aceri3\AppData\Local\Temp\build6998029222006006884.tmp\sketch_apr01b.cpp.hex:i
Using Port : \\.\COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x64
avrdude done. Thank you.
One last issue is that if I put my settings into internal memory I cant decide what time the pwm switches on the lights. Yet if I select put setting in to the code I can choose the time. How or where can I change the time for in internal memory code
thanks
Re: Wizard keeps giving error
Do you have the correct port and correct board selected?
Toolboy
Post by Toolboy »
Yes. And I solved my problem
Reset pins to original. Uploaded code. Then put the other two pin connectors in. Works 100%
Just partially blind from looking into the leds
