Hello, I'm writing from Italy, I wanted to upgrade the code inside my reefangel, so I downloaded the last .exe from the download page.
My old code didn't work anymore, so I took the examples, but whatever I do, I always have errors...
I have a screen cap, but I can't post it.......
I keep installing and unistalling, with the upgrade of the libraries or not, I always have many different errors....
I don't know what to do
This is my old pde:
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "Rita";
prog_char probe1_label[] PROGMEM = "Vasca";
prog_char probe2_label[] PROGMEM = "Stanza";
prog_char probe3_label[] PROGMEM = "-";
prog_char relay1_label[] PROGMEM = "-";
prog_char relay2_label[] PROGMEM = "DAC";
prog_char relay3_label[] PROGMEM = "Reattore%20Calcio";
prog_char relay4_label[] PROGMEM = "Vortech%20MP40";
prog_char relay5_label[] PROGMEM = "Vortech%20MP10";
prog_char relay6_label[] PROGMEM = "Freddo";
prog_char relay7_label[] PROGMEM = "Caldo";
prog_char relay8_label[] PROGMEM = "Skimmer";
ReefAngel_TimerClass MyTimer;
ReefAngel.SetTemperatureUnit(1);
// Initialize and start the timer
MyTimer.SetInterval(180); // set interval to 180 seconds
MyTimer.Start();
// Set the ports that get toggled on & off during the following modes
// To enable a port to be toggled, place a 1 in the appropriate position
// Uncomment and update as needed
// Port 87654321
ReefAngel.FeedingModePorts = B00011000;
ReefAngel.WaterChangePorts = B11111110;
//ReefAngel.OverheatShutoffPorts = B00000000;
//ReefAngel.LightsOnPorts = B00000001;
//PLAFO LED
//ReefAngel.Relay.On(Port1);
//OSMOREGOLATORE DAC
ReefAngel.Relay.On(Port2);
//Reattore Calcio
ReefAngel.Relay.On(Port3);
//SKIMMER
ReefAngel.Relay.On(Port8);
//POMPA DX
//ReefAngel.Relay.On(Port5);
//POMPA SX
//ReefAngel.Relay.On(Port4);
//ReefAngel.Refresh();
//Serial.println(ReefAngel.Params.Temp1);
//Serial.println(ReefAngel.Params.Temp2);
//Serial.println(ReefAngel.Params.Temp3);
Serial.print("La Temperatura in vasca e' ");
Serial.print("La Temperatura in casa e' ");
delay(1000);
// accensione pompa MP40
if (((NumMins(hour(),minute()) >= NumMins(11,30)) && (NumMins(hour(),minute()) <= NumMins(22,00)))) ReefAngel.Relay.On(Port4);
else ReefAngel.Relay.Off(Port4);
// accensione pompa MP10
if (((NumMins(hour(),minute()) >= NumMins(0,01)) && (NumMins(hour(),minute()) <= NumMins(12,13)))) ReefAngel.Relay.On(Port5);
else ReefAngel.Relay.Off(Port5);
// Specific functions
ReefAngel.StandardFan(Port6);
if ( MyTimer.IsTriggered() )
MyTimer.Start();
ReefAngel.WebBanner();
I need to upgrade to the portal and to have the DelayedOn function.
This library is the 0.8.3 and it doesn't have it....
This is what the Wizard shows me:
ReefAngel.FeedingModePorts = Port4Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port4Bit | Port5Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 900 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.StandardLights( Port4,11,30,22,0 );
ReefAngel.StandardLights( Port5,22,0,1,0 );
ReefAngel.StandardFan( Port6,230,275 );
ReefAngel.StandardHeater( Port7,211,241 );
ReefAngel.Relay.DelayedOn( Port8,7 );
ReefAngel.Portal( "Rita" );
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
// Date and Time
And this is the error:
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Relay Expansion Module
Simple Menu
In file included from sketch_apr03a.cpp:2:
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:682: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:714: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:718: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:719: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:720: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:721: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:882: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:886: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:888: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:895: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:898: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:899: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:900: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:901: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:907: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\Globals/Globals.h:908: error: 'byte' has not been declared
In file included from sketch_apr03a.cpp:3:
C:\Users\Greta\Documents\Arduino\libraries\RA_Wifi/RA_Wifi.h:363: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_Wifi/RA_Wifi.h:364: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_Wifi/RA_Wifi.h:366: error: 'boolean' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_Wifi/RA_Wifi.h:367: error: 'boolean' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_Wifi/RA_Wifi.h:372: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_Wifi/RA_Wifi.h:374: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_Wifi/RA_Wifi.h:378: error: variable or field 'pushbuffer' declared void
C:\Users\Greta\Documents\Arduino\libraries\RA_Wifi/RA_Wifi.h:378: error: 'byte' was not declared in this scope
C:\Users\Greta\Documents\Arduino\libraries\RA_Wifi/RA_Wifi.h:379: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_Wifi/RA_Wifi.h:381: error: 'byte' has not been declared
In file included from sketch_apr03a.cpp:4:
C:\Program Files (x86)\Reef Angel Controller\libraries\Wire/Wire.h:60: error: conflicting return type specified for 'virtual size_t TwoWire::write(uint8_t)'
C:\Users\Greta\Documents\Arduino\hardware\arduino\cores\arduino/Print.h:40: error: overriding 'virtual void Print::write(uint8_t)'
C:\Program Files (x86)\Reef Angel Controller\libraries\Wire/Wire.h:61: error: conflicting return type specified for 'virtual size_t TwoWire::write(const uint8_t*, size_t)'
C:\Users\Greta\Documents\Arduino\hardware\arduino\cores\arduino/Print.h:42: error: overriding 'virtual void Print::write(const uint8_t*, size_t)'
In file included from sketch_apr03a.cpp:9:
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:47: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:57: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:58: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:59: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:59: error: 'void RA_NokiaLCD::DrawText(int, int, int, int, int)' cannot be overloaded
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:58: error: with 'void RA_NokiaLCD::DrawText(int, int, int, int, int)'
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:60: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:61: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:62: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:63: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:64: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:65: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:66: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:70: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:72: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:76: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:77: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:78: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:81: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:84: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:87: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:88: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:89: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:90: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:91: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_NokiaLCD/RA_NokiaLCD.h:101: error: 'byte' has not been declared
In file included from sketch_apr03a.cpp:10:
C:\Users\Greta\Documents\Arduino\libraries\RA_ATO/RA_ATO.h: In member function 'virtual bool RA_ATOHighClass::IsActive()':
C:\Users\Greta\Documents\Arduino\libraries\RA_ATO/RA_ATO.h:53: error: 'digitalRead' was not declared in this scope
C:\Users\Greta\Documents\Arduino\libraries\RA_ATO/RA_ATO.h: In member function 'virtual bool RA_ATOLowClass::IsActive()':
C:\Users\Greta\Documents\Arduino\libraries\RA_ATO/RA_ATO.h:59: error: 'digitalRead' was not declared in this scope
In file included from sketch_apr03a.cpp:11:
C:\Users\Greta\Documents\Arduino\libraries\RA_Joystick/RA_Joystick.h: At global scope:
C:\Users\Greta\Documents\Arduino\libraries\RA_Joystick/RA_Joystick.h:44: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_Joystick/RA_Joystick.h:45: error: 'byte' does not name a type
In file included from sketch_apr03a.cpp:12:
C:\Users\Greta\Documents\Arduino\libraries\LED/LED.h: In member function 'void LEDClass::On()':
C:\Users\Greta\Documents\Arduino\libraries\LED/LED.h:31: error: 'HIGH' was not declared in this scope
C:\Users\Greta\Documents\Arduino\libraries\LED/LED.h:31: error: 'digitalWrite' was not declared in this scope
C:\Users\Greta\Documents\Arduino\libraries\LED/LED.h: In member function 'void LEDClass::Off()':
C:\Users\Greta\Documents\Arduino\libraries\LED/LED.h:32: error: 'LOW' was not declared in this scope
C:\Users\Greta\Documents\Arduino\libraries\LED/LED.h:32: error: 'digitalWrite' was not declared in this scope
In file included from sketch_apr03a.cpp:13:
C:\Users\Greta\Documents\Arduino\libraries\RA_TempSensor/RA_TempSensor.h: At global scope:
C:\Users\Greta\Documents\Arduino\libraries\RA_TempSensor/RA_TempSensor.h:33: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_TempSensor/RA_TempSensor.h:34: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_TempSensor/RA_TempSensor.h:36: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_TempSensor/RA_TempSensor.h:37: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_TempSensor/RA_TempSensor.h:38: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_TempSensor/RA_TempSensor.h:39: error: 'byte' does not name a type
In file included from sketch_apr03a.cpp:14:
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:37: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:38: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:39: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:40: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:43: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:44: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:44: error: 'boolean' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:46: error: 'boolean' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:51: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:52: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:53: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:55: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:56: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Relay/Relay.h:57: error: 'byte' does not name a type
In file included from sketch_apr03a.cpp:15:
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:32: error: 'boolean' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:33: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:34: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:35: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:36: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:39: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:40: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:45: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:46: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:85: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:86: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:89: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RA_PWM/RA_PWM.h:90: error: 'byte' does not name a type
In file included from sketch_apr03a.cpp:17:
C:\Users\Greta\Documents\Arduino\libraries\Memory/Memory.h:35: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Memory/Memory.h:36: error: 'byte' has not been declared
In file included from sketch_apr03a.cpp:21:
C:\Users\Greta\Documents\Arduino\libraries\Salinity/Salinity.h:30: error: 'boolean' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\Salinity/Salinity.h:33: error: 'boolean' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\Salinity/Salinity.h: In member function 'void SalinityClass::SetCompensation(int)':
C:\Users\Greta\Documents\Arduino\libraries\Salinity/Salinity.h:33: error: 'TemperatureCompensation' was not declared in this scope
In file included from sketch_apr03a.cpp:22:
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h: At global scope:
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:32: error: 'boolean' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:33: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:34: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:35: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:36: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:37: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:38: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:39: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:40: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:48: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:49: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:50: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:51: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:52: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:53: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:54: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:55: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:62: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:63: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:64: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:65: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:66: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:67: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:68: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\RF/RF.h:69: error: 'byte' has not been declared
In file included from sketch_apr03a.cpp:23:
C:\Users\Greta\Documents\Arduino\libraries\IO/IO.h:31: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\IO/IO.h:32: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\IO/IO.h:33: error: 'boolean' does not name a type
In file included from sketch_apr03a.cpp:25:
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:32: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:33: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:34: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:42: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:43: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:44: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:45: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:46: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:50: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:51: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:52: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:53: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:54: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:57: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:58: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\AI/AI.h:59: error: 'byte' has not been declared
In file included from sketch_apr03a.cpp:27:
C:\Users\Greta\Documents\Arduino\libraries\WaterLevel/WaterLevel.h:32: error: 'byte' does not name a type
In file included from sketch_apr03a.cpp:28:
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:134: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:137: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:138: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:139: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:142: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:143: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:144: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:147: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:149: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:158: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:159: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:163: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:174: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:175: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:176: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:177: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:178: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:179: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:180: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:181: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:182: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:183: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:184: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:185: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:186: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:187: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:188: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:189: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:192: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:193: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:194: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:195: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:196: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:197: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:198: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:199: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:200: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:201: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:202: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:203: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:204: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:205: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:206: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:207: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:208: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:209: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:210: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:211: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:212: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:213: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:214: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:218: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:220: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:225: error: 'byte' has not been declared
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:230: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:231: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:309: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:313: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:315: error: 'byte' does not name a type
C:\Users\Greta\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:317: error: 'byte' does not name a type
sketch_apr03a.cpp: In function 'void setup()':
sketch_apr03a:42: error: 'class ReefAngelClass' has no member named 'FeedingModePorts'
sketch_apr03a:43: error: 'class ReefAngelClass' has no member named 'FeedingModePortsE'
sketch_apr03a:45: error: 'class ReefAngelClass' has no member named 'WaterChangePorts'
sketch_apr03a:46: error: 'class ReefAngelClass' has no member named 'WaterChangePortsE'
sketch_apr03a:48: error: 'class ReefAngelClass' has no member named 'LightsOnPorts'
sketch_apr03a:49: error: 'class ReefAngelClass' has no member named 'LightsOnPortsE'
sketch_apr03a:51: error: 'class ReefAngelClass' has no member named 'OverheatShutoffPorts'
sketch_apr03a:52: error: 'class ReefAngelClass' has no member named 'OverheatShutoffPortsE'
sketch_apr03a:54: error: 'class ReefAngelClass' has no member named 'TempProbe'
sketch_apr03a:55: error: 'class ReefAngelClass' has no member named 'OverheatProbe'
sketch_apr03a.cpp: In function 'void DrawCustomMain()':
sketch_apr03a:94: error: 'class RA_PWMClass' has no member named 'GetDaylightValue'
sketch_apr03a:94: error: 'class RA_PWMClass' has no member named 'GetActinicValue'
sketch_apr03a:101: error: 'byte' was not declared in this scope
sketch_apr03a:101: error: expected `;' before 'TempRelay'
sketch_apr03a:102: error: 'TempRelay' was not declared in this scope
sketch_apr03a:102: error: 'class RelayClass' has no member named 'RelayMaskOff'
sketch_apr03a:103: error: 'class RelayClass' has no member named 'RelayMaskOn'
sketch_apr03a:108: error: 'class RelayClass' has no member named 'RelayDataE'
sketch_apr03a:109: error: 'class RelayClass' has no member named 'RelayMaskOffE'
sketch_apr03a:110: error: 'class RelayClass' has no member named 'RelayMaskOnE'
Thank you
Rita
Problems with the libraries
Re: Problems with the libraries
Yes, you definitely have missing libraries.
Please install the RA Installer and delete the folder "C:\Users\Greta\Documents\Arduino"
Then, install the RA Installer again.
Works now! Thank you!
