lnevo wrote:What happens if you start a new sketch and try hardcoding the tunze to one speed for now..lets go for basics...then change the speed and see what happens..
Lee,
The Tunze powerhead will run if I disconnect the Tunze cable. It is no longer controllable using the ReefAngel.PWM.SetDayLight channel. It will work correctly and is fully controllable if I use the ReefAngel.PWM.SetActinic channel. Something happened to the ReefAngel.PWM.SetDayLight code with the 1.0.4 library change. That is when it stopped working for me.
If you have a specific piece of code you would like me to try please post it. I would be glad to try it.
John
I'd like to see you start with fresh wizard generated code (hardcoded) and see if a SetDaylight(50); works and then try with 75. If still nothing or you did this already then nevermind.
Just want to make sure 100% its not your memory or code.
Lee,
John
Lee,
I used the Wizard to create this code using Ubuntu version 10.04 and Ardunio 1.0.1. I think I did what you suggested but here is the code.
byte buzzer=0;
byte overheatflag=0;
byte atoflag=0;
byte highfloatflag=0;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
ReefAngel.LightsOnPorts = Port8Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port7,755,790 );
ReefAngel.StandardLights( Port8,20,0,8,0 );
ReefAngel.PWM.SetDaylight( 50 );
overheatflag = InternalMemory.read( Overheat_Exceed_Flag );
atoflag = InternalMemory.read( ATO_Exceed_Flag );
// highfloatflag = ReefAngel.HighATO.IsActive();
buzzer = overheatflag + atoflag;
if ( buzzer >= 1 ) buzzer = 100;
ReefAngel.PWM.SetActinic( buzzer );
ReefAngel.Portal( "mudcat1" );
It is behaving the same way. The Tunze powerhead will not start unless I disconnect the Tunze cable. The DP channel on the Reef Angel screen displays 50. As soon as I disconnect the Tunze cable the powerhead will start running.
Lee,
I changed the code to use the Actinic channel instead of the Daylight channel and it works correctly, the powerhead runs at 50. So the problem continues to follow the Daylight channel. Here is the modified code.
lnevo wrote:Cool at least we've 100% ruled out memory and code. Guess it must be the relay box. Or libraries...
Lee,
I think I already ruled out the relay box being bad because it works correctly with the version 1.0.3 libraries.
John
Or it has something uniquely wrong that is being affected by something totally irrelevant, maybe just like my water level.
It would be interesting also to see if you modify the function that sends the final write to the port to swap daylight and actinic and see if it follows..
rimai wrote:I still can't replicate the issue.
I forced PH_Mode=2; just before the switch because I don't have the memory location you are using initialized.
I can see the values changing in the screen and using a meter, I can see it changing according to what I see in the screen. I'm not so sure what is happening in your end.
Please make sure you are using the Daylight channel because the Actinic channel is working correctly. I tested it using a simple Wizard generated sketch (per Lee's suggestion) and I still encounter the problem when using the 1.0.7 libraries. I can reproduce the problem in Windows 7 or Ubuntu 10.04. Everything works correctly in version 1.0.3.
Yeah, I'm using daylight.
The actinic is always showing 100, probably because I don't have something that you are monitoring.
I tried on both RA and RA+ boards... So, I can't seem to replicate what you are experiencing
rimai wrote:Yeah, I'm using daylight.
Yes, that makes sense because I am monitoring that status of a float switch and starts my buzzer at full volume (100) which is attached to the Actinic channel. I am not sure what else to try. I guess I will downgrade to version 1.0.3 libraries and wait and see if anyone else reports the problem in the future. I guess that is the price you pay for being an early adopter.
I decided to continue to run the 1.0.7 libraries. I switched the Tunze powerhead to the Actinic channel where it will work properly. I put the buzzer on the Daylight channel so that it will sound when my ATO container is empty. I noticed another strange new symptom. When the buzzer goes off the DP channel shows 100 and the buzzer sounds as it should, but when the ATO container is full, the ATO low float switch is activated and the DP channel displays 0 as it should, but the buzzer continues to sound. The Daylight channel continues to present current when it should not. The buzzer continues to sound for several seconds until it slowly quiets itself. I thought i should mention this new observation just in case it might steer you to a possible solution.
