Watchdog Timer
Version Menu
Simple Menu
E:\Documents and Settings\Administrator\My Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp: In member function 'void RA_NokiaLCD::SendData(byte)':
E:\Documents and Settings\Administrator\My Documents\Arduino\libraries\RA_NokiaLCD\RA_NokiaLCD.cpp:652: error: 'pingSerial' was not declared in this scope
Make sure you are using the latest libraries.
If you installed the RA installer prior to 1.0.4, I recommend you uninstall the prior version and download the latest to make sure you are getting all the related files too.
