Your code is hard coding the mode and is disabling memory.
Take out those two lines...the one saying UseMemory=false; and the one after setting it to ReefCrestMode.
new version issue
Re: new version issue
ok deleted the usememory=false but cant find the other one.
are you talking about this part of the code?
ReefAngel.DCPump.SetMode( ReefCrest,100,10 );
ok done but it still seems like its not working correctly. i can switch it between reefcrest and tidal swell but cant get it to take nutrient export or a few others. its like sometimes it works and other times it wont.
It works from my phone computer is to slow to work I guess
just on the duration note - will the duration affect Vortech pump modes as well? Say if i want to run the default Vortech ReefCrest mode, do i make duration 0 or leave it as 10?
