new version issue
jjdezek
new version issue
Post by jjdezek »
I downloaded the latest version and redid my wizard and coding for my RA went into the portal to do the wp40 set up and no matter what i do it stay at 20 on both. whats up with that?
Re: new version issue
Can you post your code?
jjdezek
Post by jjdezek »
I had to put the codes back in the custom area to get it to work. I was told with the new version you could toggle between wave modes in the portal. is this possible now?
#define NUMBERS_8x16
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    ReefAngel.WaterChangePorts = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
     ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardATO( Port1,60 );
    ReefAngel.StandardLights( Port3,18,0,10,0 );
    ReefAngel.WavemakerRandom( Port5,30,100 );
    ReefAngel.WavemakerRandom( Port6,30,100 );
    ReefAngel.StandardHeater( Port7,752,755 );
     if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(100,20,true) ); // ReefCrest at 100% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(100,20,false) ); // ReefCrest at 100% +/- 20% on anti-sync mode
else if (hour()>=12 && hour()<18)
  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,100,200,true) ); // Short pulse at 100% with 200ms pulse on sync mode
  ReefAngel.PWM.SetActinic( ShortPulseMode(0,100,200,false) ); // Short pulse at 100% with 200ms pulse on anti-sync mode
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,100,10,true) ); // Long pulse at 100% with 10s pulse on sync mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,100,10,false) ); // Long pulse at 6100% with 10s pulse on anti-sync mode
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
   ReefAngel.PWM.SetActinic(0);
   ReefAngel.PWM.SetDaylight(0);
    ReefAngel.Portal( "jjdezek" );
void DrawParamsa(int x, int y){
char buf[16];
  ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+40,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+40,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
  char buf[16];
  // Temp and PH
  y+=10;
  y+=5;
  int t=x;
Yes, but you need to generate a code with the wizard and make sure you check mark DC Pump on the attachment list.
jjdezek
Post by jjdezek »
ok found it. thanks. i was looking under the dimming portion for a jeabo option. its earlier in the wizard.
jjdezek
Post by jjdezek »
what is the duration under the portal do?
It's the length of the cycles for short and long pulse.
jjdezek
Post by jjdezek »
Ok I set it up for reefcrest at 100% and duration of 9 and my power head is not working now
Can you post the code?
jjdezek
Post by jjdezek »
its running now but im not able to switch from one mode to another in the portal. it just stays in the reefcrest mode. also i set it at 100% yet it will go up to 120% on the display and in the portal. is it really running that high?
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    ReefAngel.Wavemaker( Port5,60 );
    ReefAngel.Wavemaker( Port6,60 );
    ReefAngel.StandardHeater( Port7,751,761 );
    ReefAngel.DCPump.SetMode( ReefCrest,100,10 );
char buf[16];
  char buf[16];
  // Temp and PH
  y+=10;
  y+=5;
  int t=x;
Your code is hard coding the mode and is disabling memory.
Take out those two lines...the one saying UseMemory=false; and the one after setting it to ReefCrestMode.
jjdezek
Post by jjdezek »
ok deleted the usememory=false but cant find the other one.
jjdezek
Post by jjdezek »
are you talking about this part of the code?
Yes.
jjdezek
Post by jjdezek »
ok done but it still seems like its not working correctly. i can switch it between reefcrest and tidal swell but cant get it to take nutrient export or a few others. its like sometimes it works and other times it wont.
jjdezek
Post by jjdezek »
It works from my phone computer is to slow to work I guess
Poiromaniax
Post by Poiromaniax »
just on the duration note - will the duration affect Vortech pump modes as well? Say if i want to run the default Vortech ReefCrest mode, do i make duration 0 or leave it as 10?
Duration is not used by reefcrest
Poiromaniax
