ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.DayLights( Port2 );
ReefAngel.StandardFan( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.DayLights( Port6 );
ReefAngel.PWM.Channel0PWMSlope();
ReefAngel.Portal( "pandimus" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Dimming Expansion Module
Simple Menu
Binary sketch size: 32,556 bytes (of a 32,256 byte maximum)
processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
at processing.app.Sketch.size(Sketch.java:1844)
at processing.app.Sketch.build(Sketch.java:1775)
at processing.app.Sketch.build(Sketch.java:1750)
at processing.app.Editor$DefaultRunHandler.run(Editor.java:1867)
at java.lang.Thread.run(Thread.java:619)
