custom main
Re: custom main
One thing you can do is set the timeout to something over 24hrs.
It has to be tested to make sure the timer will take this value.
Then, you can use the ReefAngel.LCD.BacklightOn() and ReefAngel.LCD.BacklightOff() for night and day.
Something like this:
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
//custom dysplay temp+on and off relay
   byte x = 6;
   byte y = 2;
   byte t;
   ReefAngel.LCD.DrawDate(6, 2);
   x = 12;
   y += MENU_START_ROW+1;
   char text[7];
   ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
   y += MENU_START_ROW*2;
   x = 10;
   x += (16*4) + 8;
   ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
   randomSeed(analogRead(0));
   ReefAngel.Timer[1].SetInterval(random(10,InternalMemory.WM1Timer_read()));
   ReefAngel.Timer[1].Start();
   ReefAngel.Relay.On(Port6);
   ReefAngel.FeedingModePorts = B00110000;
   ReefAngel.OverheatShutoffPorts = B00001110;
   ReefAngel.WaterChangePorts = B11110001;
   ReefAngel.Relay.On(Port8);
   ReefAngel.Relay.On(Port7);
   ReefAngel.Timer[LCD_TIMER].SetInterval(90000);
   // Specific functions
   //ReefAngel.StandardATO(Port1);
   ReefAngel.StandardLights(Port2, 11, 00, 20, 00);
   ReefAngel.StandardLights(Port3, 10, 00, 22, 00);
   ReefAngel.StandardHeater(Port4);
   //wave maker fonction with night mode
   if ( (hour() >= 22) || (hour() <= 8) ) // from 10p - 8a
      ReefAngel.Relay.Off(Port6);
      ReefAngel.Relay.On(Port5);
      ReefAngel.LCD.BacklightOff();
      // during the day
         ReefAngel.Timer[1].SetInterval(random(25,50));
         ReefAngel.Relay.Toggle(Port6);
      ReefAngel.LCD.BacklightOn();
wijigong
Re: custom main
Post by wijigong »
hehhee
tank you
i try it
Re: custom main
rimai wrote:One thing you can do is set the timeout to something over 24hrs.
The max value a timer can hold is something like 4 billion because it's an unsigned long (4 byte) variable. The problem you will get into though is that the function to set the interval is only an int (2 byte) variable which can only hold a value like 32,767. There is 86,400 seconds in a day. You "might" be able to set the value manually but you won't be able to store it in the internal memory the way it is because the LCD Timer is set to be an int storage. You will also have to manually set that timeout inside the setup function too. So you would need something like this inside your setup function:
    ReefAngel.Init();
    ReefAngel.Timer[LCD_TIMER].SetInterval(86400);  // LCD Sleep Mode timer
    ReefAngel.Timer[LCD_TIMER].Start();  // start timer
    // rest of functions here
It's worth a shot to test.
wijigong
Re: custom main
Post by wijigong »
hello
i try this last weekend, i work find but when the screen is black(after 22h) if i push the jostick the screen dont come on
i think is need somethin like if (ReefAngel.Joystick.IsButtonPressed()) with minimum time for the screen
thank you again
Re: custom main
Try this one:
   byte x = 6;
   byte y = 2;
   byte t;
   x = 12;
   char text[7];
   x = 10;
   x += (16*4) + 8;
      ReefAngel.Timer[LCD_TIMER].SetInterval(60);
      // during the day
wijigong
Re: custom main
Post by wijigong »
finaly is very simple
i juste keep the line
and is work great
the day is alway on and after 10pm i use the memory setting
Re: custom main
Cool :)
Nice and easy :)
