Hi I need 2 things for my vortech pump with RF expansion module :
First
I want to make my vortech pumnp to run through different modes through the day
and make it sleep mode at night (like the one with vortech setup )
second
I nnoticed that she I press feeding on RA menue it didn't transfer the mode to feeding while pressing it from portal it will switch the vortech to feeding mode !?
what should I do to solve this ?
thanks
Vortech setup with RF expansion
Re: Vortech setup with RF expansion
This may help, I set mine to change every hour.
Not sure what you mean by sleep but you may be able to set it to constant between 9pm and 6 am
else if (hour()>=21 && hour()<6)
ReefAngel.RF.SetMode(Constant,50,10);
hth
if ( ReefAngel.RF.Mode != Feeding_Start)
if (hour()==10)
ReefAngel.RF.SetMode(ReefCrest,30,20);
else if (hour()>=0 && hour()<1)
ReefAngel.RF.SetMode(Lagoon,80,15);
else if (hour()>=1 && hour()<2)
ReefAngel.RF.SetMode(Lagoon,60,20);
else if (hour()>=2 && hour()<3)
ReefAngel.RF.SetMode(Lagoon,40,25);
else if (hour()>=3 && hour()<4)
else if (hour()>=4 && hour()<5)
ReefAngel.RF.SetMode(Lagoon,70,10);
else if (hour()>=5 && hour()<6)
ReefAngel.RF.SetMode(Lagoon,60,15);
else if (hour()>=6 && hour()<7)
ReefAngel.RF.SetMode(Lagoon,30,20);
else if (hour()>=7 && hour()<8)
ReefAngel.RF.SetMode(Lagoon,40,30);
else if (hour()>=8 && hour()<9)
ReefAngel.RF.SetMode(Lagoon,50,20);
else if (hour()>=9 && hour()<10)
ReefAngel.RF.SetMode(Lagoon,60,10);
else if (hour()>=10 && hour()<11)
ReefAngel.RF.SetMode(Lagoon,80,5);
else if (hour()>=11 && hour()<12)
ReefAngel.RF.SetMode(Smart_NTM,80,6);
else if (hour()>=12 && hour()<13)
ReefAngel.RF.SetMode(Smart_NTM,70,10);
else if (hour()>=13 && hour()<14)
ReefAngel.RF.SetMode(Smart_NTM,60,12);
else if (hour()>=14 && hour()<15)
ReefAngel.RF.SetMode(Smart_NTM,50,10);
else if (hour()>=15 && hour()<16)
ReefAngel.RF.SetMode(Smart_NTM,40,8);
else if (hour()>=16 && hour()<17)
ReefAngel.RF.SetMode(Lagoon,50,10);
else if (hour()>=17 && hour()<18)
else if (hour()>=18 && hour()<19)
ReefAngel.RF.SetMode(Constant,60,10);
else if (hour()>=19 && hour()<20)
else if (hour()>=20 && hour()<21)
ReefAngel.RF.SetMode(Constant,40,10);
else if (hour()>=21 && hour()<22)
ReefAngel.RF.SetMode(Lagoon,45,10);
else if (hour()>=22 && hour()<23)
else if (hour()>=23 && hour()<0)
ReefAngel.RF.SetMode(ReefCrest,40,8);
hth
