3rd dosometric pump
Re: 3rd dosometric pump
Create another memory value for offset and duration1 duration2 so you can have a different duration for each pump if you want, then instead of using just hour min seconds duration on the second pump you would use hour min+offset. Seconds duration
I was thinking about using this function which is available in the dev. libraries file reefangel.cpp, because it already has everything setup for it in memory except the offset so all i need to figure out is how i could modify this function to add an offset for doser2
void ReefAngelClass::DosingPumpRepeat(byte DPRelay, byte DPTimer, int RepeatMinute, byte RunTime)
This function runs the specified relay for the RunTime seconds every RepeatMinute minutes.
So you can run the relay for 10 seconds every 60 minutes (1 hour)
This function bases the RepeatMinute off of Midnight (00:00) of the current day. It uses midnight to
compute when the pump will run.
DPRelay - Relay that contains the dosing pump
Timer - number of the timer in the timer array to use
RepeatMinute - number of minutes to wait before running the pump again
RunTime - duration (in seconds) to run the pump
// if the current minutes since midnight are divisible by the repeat interval and the current seconds
// are zero (top of the minute), then we can run the pump
time_t t = now();
uint8_t h = hour(t);
if ( (h == 0) && (minute(t) == 0) )
// if we are at midnight, change hours to 24 so we can get the correct minutes for computation
h = 24;
int current_min = NumMins(h, minute(t));
int r = current_min % RepeatMinute;
if ( (r == 0) && (second(t) == 0) )
Relay.On(DPRelay);
Timer[DPTimer].SetInterval(RunTime);
Timer[DPTimer].Start();
// Should change the timer to be a Dosing Pump Timer
// is the timer expired?
if ( Timer[DPTimer].IsTriggered() )
Relay.Off(DPRelay);
Deckoz2302 wrote:Create another memory value for offset and duration1 duration2 so you can have a different duration for each pump if you want, then instead of using just hour min seconds duration on the second pump you would use hour min+offset. Seconds duration
what about if i wanna change the interval?
What interval where you looking to do? Odd numbers, even numbers. Interval how rimai posted was when minutes from time equal 0 and seconds are under 4. You could do something like.
if (ReefAngel.DisplayedMenu==255 && hour() % memvar# == 0 && minute()==0 && second()<4)
Relay on
Else
Off
Its not true code just an idea. For even numbers - set memvar# as 2, for odd numbers flip the on off. Ie if statement would be off else would be on. Or you could do every 3 hours setting memvar. As 3, or every 8 setting it as 8. So you don't. Have to plug into the reef angel to switch between odd & even you could creat another memvar with if statment, set it as 0 for even, 1 for odd and write a statement in loop
If (memvar# ==0) even();
Else (memvar#==1) odd();
Then create a function for each odd and even, or you could skip writing a function and do a boolean statement. Sorry I'm on my phone ill type something out when I get home hope it makes sense
Relay on
Else
Off
actually i was thinkin of shortening the interval period cause my dosers are 1ml/min so they are very slow thats why I might wanna dose every 30 minutes for example. so i want to be able to set the interval in minutes so that if i want to set it less than an hour i could and if i wanna set it more than an hour I d still be able to. At the same time I still want to offset the dosers from each other.
what about if i do this:
if (ReefAngel.DisplayedMenu==255 && minute() % memvar# == 0 && second()<InternalMemory.DP1Timer_read())
then if i set memvar to 30 I d be dosing every 30 minutes, correct? how could i offset now?
I think you could do == 0 + 5
Well, it would work... But, here is my point of view.
If you for example change the memvar to let's say 25, the doser will be activated at xx:00, XX:25 and XX:50. It would not be an even 25 minutes throughout the day.
If you want an even distribuition throughout the day, you will need to compare it to number of minutes from midnight.
So, the function would be something like this:
You can use a defined memory location DP1OnMinute to store your minutes interval. Just keep in mind not to use any of the DosingPump or DosingPumpInterval functions.
The offset can be done by just changing the 0 on the comparison.
The below would have a 5 minute offset from the first.
Give it a shot and see if it works.
if (ReefAngel.DisplayedMenu==255 && NumMinutes(hour(),minute()) % InternalMemory.DP1OnMinute_read() == 0 && second()<InternalMemory.DP1Timer_read())
if (ReefAngel.DisplayedMenu==255 && NumMinutes(hour(),minute()) % InternalMemory.DP1OnMinute_read() == 5 && second()<InternalMemory.DP1Timer_read())
tested the functions above, the offset works fine but the duration does not because as soon as the current time jumps to the next minute the condition no longer becomes true because of this part "NumMinutes(hour(),minute()) % InternalMemory.DP1OnMinute_read() == 0"rimai wrote:Well, it would work... But, here is my point of view.
So, the function would be something like this:You can use a defined memory location DP1OnMinute to store your minutes interval. Just keep in mind not to use any of the DosingPump or DosingPumpInterval functions.Code: Select all
The below would have a 5 minute offset from the first.Give it a shot and see if it works.Code: Select all
so the doser gets turned off as soon as 1 minute passes
Yeah, this code won't work then.
Turns out you will indeed have to use something similar to the DosingPumpRepeat()
In the code above, we are using just DP1OnMinute for both doser to make sure they are in sync and only 5 minutes apart.
DP1Timer and DP2Timer can be different, so you can have different dosages for pump1 and pump2.
Let me know if it works this way.
if (ReefAngel.DisplayedMenu==255 && (NumMins(hour(),minute()) % InternalMemory.DP1OnMinute_read()) == 0 && second() == 0)
ReefAngel.Timer[1].SetInterval(InternalMemory.DP1Timer_read()); // Read DP1Timer
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port1);
if (ReefAngel.Timer[1].IsTriggered())
ReefAngel.Relay.Off(Port1);
if (ReefAngel.DisplayedMenu==255 && (NumMins(hour(),minute()) % InternalMemory.DP1OnMinute_read()) == 5 && second() == 0)
ReefAngel.Timer[2].SetInterval(InternalMemory.DP2Timer_read()); // Read DP2Timer
ReefAngel.Timer[2].Start();
ReefAngel.Relay.On(Port2);
if (ReefAngel.Timer[2].IsTriggered())
ReefAngel.Relay.Off(Port2);
Its workin fine now, thanks
rimai wrote:Yeah, this code won't work then.
Turns out you will indeed have to use something similar to the DosingPumpRepeat()In the code above, we are using just DP1OnMinute for both doser to make sure they are in sync and only 5 minutes apart.Code: Select all
if (ReefAngel.DisplayedMenu==255 && (NumMins(hour(),minute()) % InternalMemory.DP1OnMinute_read()) == 0 && second() == 0) { ReefAngel.Timer[1].SetInterval(InternalMemory.DP1Timer_read()); // Read DP1Timer ReefAngel.Timer[1].Start(); ReefAngel.Relay.On(Port1); } if (ReefAngel.Timer[1].IsTriggered()) { ReefAngel.Relay.Off(Port1); } if (ReefAngel.DisplayedMenu==255 && (NumMins(hour(),minute()) % InternalMemory.DP1OnMinute_read()) == 5 && second() == 0) { ReefAngel.Timer[2].SetInterval(InternalMemory.DP2Timer_read()); // Read DP2Timer ReefAngel.Timer[2].Start(); ReefAngel.Relay.On(Port2); } if (ReefAngel.Timer[2].IsTriggered()) { ReefAngel.Relay.Off(Port2); }
if i want to be able to change the dosing interval using the memory location "InternalMemory.DP1RepeatInterval" lets say change it from repeating the dose every hour to repeating the dose every 30 minutes, how do i code that?
