Backup power?
Posted: Tue Oct 22, 2013 7:21 pm
by Dctrojan
Is there a way to program the reef angel to run a "life support " function on backup batteries when the lights go out.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Backup power?
Posted: Tue Oct 22, 2013 8:11 pm
Yes i am doing that but you need a way to detect the power outage. Two ways I know that you can do it.
1) 2 relay boxes (1 on backup 1 not)
When power is lost relay expansion is not detected and we trigger life support function.
2) Input detection. With an available float switch port or io module port you can connect to a relay that is powered by a 5v or 12v power supply. You plug that in to no a non-ups port and then you monitor that port to trigger your function
I'm using method 1
Re: Backup power?
Posted: Tue Oct 22, 2013 10:23 pm
by Dctrojan
Hmm ill definitely look into this. I like number option number 2 due to the diy possibility and cheaper cost. What are you using for a power source when the lights go out
Re: Backup power?
Posted: Wed Oct 23, 2013 4:39 am
I'm just using a UPS
