1.1.10 Issues
Posted: Sun Nov 03, 2013 8:06 am
A few issues I wanted to report that I'm working through with the new libraries.
1) My OVERRIDE_PORTS macro in feature.txt is STILL not included... From the PULL request info https://github.com/reefangel/Libraries/pull/90
OVERRIDE_PORTS,ReefAngel.AddPortOverrides,Override Port Masks
Are you getting my PMs? Sent a few reminders on this one and also regarding adding the WiFiAlert.. seems I can no longer make pull requests to the dev branch it defaults to master.. not sure what I'm doing wrong..
2) ScheduleTime() function was removed... I was using this in the Moon rise/set lib. Not a big deal, I copied the function from the old libraries into that code.
3) boolean / byte do not name types... Not sure what I'm missing here, but could use some guidance... assuming I'm missing an include..
/home/lnevo/sketchbook/libraries/SunLocation/SunLocation.h:22: error: ‘boolean’ does not name a type
/home/lnevo/sketchbook/libraries/SunLocation/SunLocation.h:35: error: ‘boolean’ does not name a type
/home/lnevo/sketchbook/libraries/SunLocation/SunLocation.h:57: error: ‘byte’ does not name a type
This has worked fine in the past few libraries and the SunLocation code has not changed in a long time...
