Updated to 1.1.0, Screen dead
Posted: Sun Nov 03, 2013 1:55 pm
by bobachew
I updated to the new libraries today and now my screen is random colors and lines. I removed my custom screen and graph code and the problem is still there. The attached code is the stripped down version, my portal and app still work normally only the controller screen is not operating normally. I attempted updating the code multiple times with the same result, it is a non plus ra, with a gen 1 screen and wifi.
Re: Updated to 1.1.0, Screen dead
Posted: Sun Nov 03, 2013 1:59 pm
Try adding this to your setup() section:
Posted: Sun Nov 03, 2013 2:08 pm
by bobachew
It did change things, now the screen is just all black but backlit. I attached the code to make sure I placed the command in the correct place. Thanks for your help.
Posted: Sun Nov 03, 2013 2:13 pm
My bad...
Misread the 1st post.
Gen 1 needs to be like this:
It's placed correctly.
Posted: Sun Nov 03, 2013 3:06 pm
by bobachew
Well now its back to the random colors and lines again. I attached my code with the custom menu and graph. I tried loading this code (with the line you suggested) to see if that made any difference. Unfortunately, no.
Posted: Sun Nov 03, 2013 4:11 pm
I think it is unrelated to the lib update.
Your screen may just be bad.
Can you check if it is properly seated?
Posted: Sun Nov 03, 2013 4:21 pm
by bobachew
I reseated the screen with no changes, it is just weird that it worked perfectly until I updated the library and then controller.
Posted: Sun Nov 03, 2013 5:10 pm
Does it do that with the example codes too?
Posted: Sun Nov 03, 2013 5:29 pm
by bobachew
When I load examplecode1 I go back to a black screen.
