Else mode in new libraries?
PostPosted: Sat Nov 30, 2013 5:18 am
Is the else mode included in the new libraries?
I still have this code at the end of my sketch. If the else mode is included in the new libraries then I can remove this piece of code, right?
if (WaveSync)
return NewSpeed;
return AntiSpeed;
PostPosted: Sat Nov 30, 2013 7:33 am
Not in the libraries. Not sure if it will be...it's very close to the reef-crest code.
PostPosted: Wed Dec 24, 2014 3:09 am
my apologies for hijacking this thread....but I am experiencing a problem..I opened arduino today and it told me there is an update...I updated and now my code wont load onto the controller..i have the following error
"Globals\Globals.cpp.o: In function `ElseMode(unsigned char, unsigned char, unsigned char)':
C:\Users\Ridwaan.DellUser-PC\Documents\Arduino\libraries\Globals/Globals.cpp:881: multiple definition of `ElseMode(unsigned char, unsigned char, unsigned char)'
sketch_nov09a.cpp.o:C:\Users\RIDWAA~1.DEL\AppData\Local\Temp\build8546684784534505203.tmp/sketch_nov09a.cpp:156: first defined here
c:/program files (x86)/reef angel controller/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions"
I am not sure what to do?..please help
PostPosted: Wed Dec 24, 2014 3:10 am
Also, just to keep in mind..i am not a programmer...But im good at copying and psting and that's how I got my reef angel working the way I like it...lol
so yes, I need your help asap
PostPosted: Wed Dec 24, 2014 5:01 am
You need to take the ElseMode section out of your code. What this error says is that it exists twice. Once in your code, and now, once in the libraries.
Post your code and I can show you what to take out.
PostPosted: Wed Dec 24, 2014 5:46 am
Cool Thanks so much...here is my code
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
    ReefAngel.StandardLights( Port1,6,45,19,15 );
    ReefAngel.StandardLights( Port2,11,45,17,30 );
    ReefAngel.StandardHeater( Port3,240,255 );
    ReefAngel.StandardHeater( Port4,240,255 );
    ReefAngel.StandardFan( Port5,260,265 );
    ReefAngel.CO2Control( Port7,650,660 );
static unsigned long atoTimer;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) atoTimer=now();
if (now()-atoTimer < 300) { //300 second delay (five minutes)
  ReefAngel.Relay.Off(Port6);
  ReefAngel.SingleATO( true,Port6,20,0 );
if (hour()>=7 && hour()<10)
    ReefAngel.PWM.SetDaylight( LongPulseMode(0,80,5,true) ); // Ramp from 0% to 80% with 5 second duration in antisync mode
    ReefAngel.PWM.SetActinic( LongPulseMode(0,80,5,false) );
if (hour()>=10 && hour()<17)
    ReefAngel.PWM.SetDaylight( ElseMode(80,20,true) ); // ReefCrest at 80% +/- 20% on antisync mode
    ReefAngel.PWM.SetActinic( ElseMode(80,20,false) );
else if (hour()>=17 && hour()<20)
     ReefAngel.PWM.SetDaylight( LongPulseMode(0,80,10,true) ); // Ramp from 0% to 80% with 10 second duration in antisync mode
     ReefAngel.PWM.SetActinic( LongPulseMode(0,80,10,false) );
    else if (hour()>=20 || hour()<7)
    ReefAngel.PWM.SetDaylight( ElseMode(30,10,true) ); // ReefCrest at 80% +/- 20% on antisync mode
    ReefAngel.PWM.SetActinic( ElseMode(30,10,false) );
        ReefAngel.Relay.Off(Port8);
        ReefAngel.Relay.On(Port8);
  if( ReefAngel.DisplayedMenu==FEEDING_MODE )
   ReefAngel.PWM.SetActinic(0);
   ReefAngel.PWM.SetDaylight(0);
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
PostPosted: Wed Dec 24, 2014 5:54 am
I think this should do it. I just removed the ElseMode() function from your code, since it's in the new libraries now.
PostPosted: Wed Dec 24, 2014 7:09 am
Thanks...that worked!
Learnt something new...
PostPosted: Mon Aug 22, 2016 5:02 am
Is it possible to change Display Mode of grid/fields by Javascripts in Dynaform, if yes, how to compile the scripts, can you make an example.
Thanks.
