Error: 'class DCPumpClass' has no member named 'LowATOChann
PostPosted: Thu Dec 12, 2013 8:30 am
I have just downloaded the 1.1.0. library and on compilation of my live code sketch I am getting the following erro: 'class DCPumpClass' has no member named 'LowATOChann
I am using the LowATO channel to control the DC pump and it has been working fine under 1.0.9. The code I have been using is shown below.
The question is, has the ReefAngel.DCPump.LowATOChannel function been changed in the latest software and any suggestion on how I can resolve the problem?
// *****************************JEBOA setup 16-09-13 *****************************
    ReefAngel.DCPump.FeedingSpeed=60;
    ReefAngel.DCPump.LowATOChannel=Sync;
PostPosted: Thu Dec 12, 2013 3:58 pm
Thought roberto incorporated that.. Did you download that from my git repo?
PostPosted: Thu Dec 12, 2013 6:41 pm
I don't think I got a pull request. Did I?
PostPosted: Thu Dec 12, 2013 7:01 pm
No idea. Probably not I guess. Can you pull the branch and get it merged??? All my git is based on 1.0.9 no idea how to bring it up to speed...
PostPosted: Thu Dec 12, 2013 7:02 pm
That and wifialert changes i'd like to push too...p.i.m.a.!!
PostPosted: Thu Dec 12, 2013 7:03 pm
I will stay on 1.0.9 for now. If you could incorporate the change I would be greatful.
Many thanks.
PostPosted: Sun Jan 12, 2014 5:37 am
I did use the build from your git.
Do you have any idea when the next library build will be out and if the LowATOChann will be included.
Regards
PostPosted: Sun Jan 12, 2014 6:15 am
I updated git for the new libs and pushed to roberto. You can download from mine again or wait till next release :)
PostPosted: Mon Jan 13, 2014 5:35 am
Thank you Lee once again for your help.
Regards
PostPosted: Tue Apr 15, 2014 1:28 pm
Hey guys, any word on this?
I am on 1.1 and have my DC pump on the ATO port. I tried the
And now I'm getting the DCPump has no member compilation error. Is there a way to use wizard with the DC pump on the Low ATO with libraries at 1.1?
Next
