Check library version fails
Posted: Fri Jan 03, 2014 11:15 am
Hi everyone. New computer and it came with windows 8.1 but this was working on my 7 box which went kaput. Anyway, trying to connect back up to my Reef Angel and running into some errors. I have the Reef Angel Client working which is great. However, when I try to use the Arduino Reef Angel client to load my last saved sketch it is throwing me an error like below. It compiles fine but if I try and do something simple has check latest version of development libraries (which is what, 1.10 now? I'm on 1.09) it fails.
Any ideas? It did have me download and install a new version of Arduino which is 1.0 5 I believe.
Thanks.
-scott
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: processing.app.Editor.getBase()Lprocessing/app/Base;
at template.tool.RALibsVer.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Thanks.
-scott
