Problem with Dosometric
lukeluke
Post by lukeluke »
i have the .19 release.
i change the value 812 memory trought the java client of Curt. i set it to 2 and i see that is at 2.
But when the function start :
ReefAngel.DosingPump(Port3, 1, 23, 00, InternalMemory.DP1Timer_read());
the on status don't run for 2 seconds, but for 6 seconds.
Why ? is changed somethings ?
Thanks a lot.
Re: Problem with Dosometric
lukeluke wrote:i have the .19 release.
Thanks a lot.
Nothing has changed. If it runs for longer than desired, there could be other stuff in your PDE file that are taking longer to run than that function should run for. Every time the function is called, it checks if it should run or not. Could you post your PDE file for review to see if we can reproduce the problem and see if anything else is affecting it?
lukeluke
Post by lukeluke »
on my office's pc, i have only this my pde:
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
int DP3_Timer = InternalMemory.DP1Timer_read() * 4;
//Disegno schermo principale
 // Change the 30 to adjust the horizontal position of the text on the screen, max 20-21 chars
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 15, 15, "LukeLuke's Cube");
  ReefAngel.LCD.DrawMonitor(15, 35, ReefAngel.Params,
  ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 6, 70, "DP1:");
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 31, 70, InternalMemory.DP1Timer_read());
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 46, 70, "DP2:");
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 71, 70, InternalMemory.DP2Timer_read());
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 86, 70, "DP3:");
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 111, 70, DP3_Timer);
  // draw main relay
  ReefAngel.LCD.DrawOutletBox(12, 87, TempRelay);
#ifdef RelayExp
  // draw 1st expansion relay
  ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
#endif  // RelayExp
void ConvertNumToString(char* string, int num, byte decimal)
	char temptxt[3];
	int Temp = num;
	if (Temp==0xFFFF) Temp=0;
		itoa(Temp/decimal,string,10);
	if (decimal>1)
		itoa(Temp%decimal,temptxt,10);
		strcat(string, ".");
		if (Temp%decimal<10 && decimal==100) strcat(string, "0");
			strcat(string, temptxt);
	byte x = 6;
	byte y = 2;
	byte t;
	ReefAngel.LCD.DrawDate(6, 2);
	x = 12;
	y += MENU_START_ROW+4;
	ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),DPColor, x, y, 1);
	t = intlength(ReefAngel.PWM.GetDaylightValue()) + 1;
	t *= 5;
	ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x+t, y, "%");
	t += 10;
	x += t;
	ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x, y, 1);
	t = intlength(ReefAngel.PWM.GetActinicValue()) + 1;
	t *= 5;
	ReefAngel.LCD.DrawText(APColor, DefaultBGColor, x+t, y, "%");
	t += 10;
	x += t;
	char text[7];
	ReefAngel.LCD.Clear(DefaultBGColor, x+16, y, x+45, y+16);
	ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+16, y, text,Font8x16);
	ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
	y += MENU_START_ROW*2;
	x = 10;
	ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
	ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
	x += (16*4) + 8;
	ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,x,y,"T2:");
	ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor, x+18, y, 10);
	ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x,y+10,"T3:");
	ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor, x+18, y+10, 10);
	y += 16*2;
	x = 8;
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x, y, "DP1:");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+25, y, InternalMemory.DP1Timer_read());
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+37, y, "DP2:");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+62, y, InternalMemory.DP2Timer_read());
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+75, y, "DP3:");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+101, y, DP3_Timer);
        x = 6;
	y += MENU_START_ROW+6;
        y -= 3;
        ReefAngel.LCD.Clear(COLOR_BLACK, x, y, 124, y);
        y +=1;
        ReefAngel.LCD.Clear(COLOR_BLUE, x+1, y, 123, y+10);
        y +=11;
        ReefAngel.LCD.Clear(COLOR_BLACK, x, y-11, x, y+16);
        ReefAngel.LCD.Clear(COLOR_BLACK, 124, y-11, 124, y+16);
        ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLUE, x+40, y-9, "Alarms");
        y += 6;
        x += 2;
	byte fcolor;
	// This is for the LOW Ato switch
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+2, y,"ATO:");
	if ( InternalMemory.read(700) == 1 )
		// add in InternalMemory.write(700, 1) when ato is tripped
		// add in InternalMemory.write(700, 0) when ato is cleared
		fcolor = COLOR_RED;
		ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+30, y, "YES");
		fcolor = COLOR_GREEN;
		ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+30, y, "NO ");
	ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+55, y,"OverH:");
	if ( InternalMemory.read(701) == 1 )
		// add in InternalMemory.write(701, 1) when overheat is tripped
		// add in InternalMemory.write(701, 0) when overheat is cleared
		fcolor = COLOR_RED;
		strcpy(text, "YES");
		strcpy(text, "NO ");
	ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+94, y, text);
        ReefAngel.LCD.Clear(COLOR_BLACK, x-2, y+11, 124, y+11);
	x = 12;
	y += 18;
 // ReefAngel.LCD.DrawGraph(5,50);
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.PWM.SetActinic(0);
    ReefAngel.PWM.SetDaylight(0);
    //WifiAuthentication("lukeluke:Luca123");
    // Set the ports that get toggled on & off during the following modes
    // To enable a port to be toggled, place a 1 in the appropriate position
    // Uncomment and update as needed
    // Port 87654321
    ReefAngel.FeedingModePorts = B00000011;
    ReefAngel.WaterChangePorts = B00000011;
    ReefAngel.OverheatShutoffPorts = B00001011;
    //ReefAngel.LightsOnPorts = B00000110;
//    ReefAngel.Relay.On(Port4);  //Turn the Skimmer
    ReefAngel.Relay.On(Port2);
   // ReefAngel.Relay.On(Port1);
    // Specific functions
    ReefAngel.SingleATOHigh(Port6);
    ReefAngel.StandardFan(Port1);
    ReefAngel.StandardHeater(Port8);
    ReefAngel.DelayedOn(Port4,10);
    if (ReefAngel.Params.Temp1 > 290)
        ReefAngel.PWM.SetActinic(PWMSlope(12,15,23,45,0,InternalMemory.LEDPWMActinic_read(),90,ReefAngel.PWM.GetActinicValue()));
        ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,30,0,40,30,ReefAngel.PWM.GetDaylightValue()));
    else if (ReefAngel.Params.Temp1 > 280)
        ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,30,0,70,30,ReefAngel.PWM.GetDaylightValue()));
       ReefAngel.PWM.SetDaylight(PWMSlope(13,30,22,30,0,InternalMemory.LEDPWMDaylight_read(),30,ReefAngel.PWM.GetDaylightValue()));
    ReefAngel.DosingPump(Port3, 1, 05, 00, InternalMemory.DP1Timer_read());
    ReefAngel.DosingPump(Port3, 1, 11, 00, InternalMemory.DP1Timer_read());
    ReefAngel.DosingPump(Port3, 1, 17, 00, InternalMemory.DP1Timer_read());
    ReefAngel.DosingPump(Port5, 2, 23, 10, InternalMemory.DP2Timer_read());
    ReefAngel.DosingPump(Port5, 2, 05, 10, InternalMemory.DP2Timer_read());
    ReefAngel.DosingPump(Port5, 2, 11, 10, InternalMemory.DP2Timer_read());
    ReefAngel.DosingPump(Port5, 2, 17, 10, InternalMemory.DP2Timer_read());
    ReefAngel.DosingPump(Port7, 4, 23, 20, DP3_Timer); // Setup Dosing Pump 3 Oligo
in the latest i change the PWM because i use the MH now .....
I don't see anything wrong with it.
