What's SAM3X8E?
PostPosted: Fri May 16, 2014 1:20 pm
I keep seeing some if defined (__SAM3X8E__), but can't figure out if I should care to modify those parts or what. Is that a new version of the controller in development like RA_STAR and RA_MINI and RA_TOUCHDISPLAY and some of the other defines I see floating around?
PostPosted: Fri May 16, 2014 3:55 pm
Yeap... new board prototype I have. It's based on a 32bit processor. The major advantage is that you can connect a tablet directly to the head unit and have android talk straight to the controller instead of using WiFi.
Sent from my SM-G900P using Tapatalk
PostPosted: Fri May 16, 2014 4:40 pm
rimai wrote:Yeap... new board prototype I have. It's based on a 32bit processor. The major advantage is that you can connect a tablet directly to the head unit and have android talk straight to the controller instead of using WiFi.
Cool. Where is the code for VariableSpeed class located instead of the PWM class? Is it in the repo or should I just not worry about it for now.
PostPosted: Fri May 16, 2014 5:41 pm
There isn't any code. It is just an alias of PWM. I couldn't use PWM because it is integral part of the internal libraries of Arduino, so I had to change it to something other than PWM.
PostPosted: Fri May 16, 2014 5:48 pm
rimai wrote:There isn't any code. It is just an alias of PWM. I couldn't use PWM because it is integral part of the internal libraries of Arduino, so I had to change it to something other than PWM.
Got it. When I do calls to Set16Channel for the PWM class I will do the same with a different name for the VariableSpeed calls.
PostPosted: Sat May 17, 2014 5:38 am
Been reading on that chip which also seems to be used in the Due. Seems to support variable bit output on the analog out pins up to 12bit. I assume you'd do 12-bit, because why not, so in all of those if blocks should I assume it's going to get that many levels of dimming even on the Actinic, Daylight, and ATO pins?
PostPosted: Sat May 17, 2014 7:48 am
Yeap. You are right :)
I never thought of that. 12bit resolution on the PWM channels.
PostPosted: Sat May 17, 2014 7:49 am
And now that you mentioned, I may have overlooked one thing. I will have to double check my design to confirm the ATO ports are mapped to PWM ports. I don't think they are.
PostPosted: Sat May 17, 2014 4:31 pm
If you do bring it out as a controller at some point it will be seriously nice. A pile of pins available.
