Single ATO
PostPosted: Thu May 22, 2014 12:47 pm
Hi Guys
If I want to use the SingleATO for the following!
The low-switch controls the sump level and the high-switch to act as a failsafe if the low-switch should get stuck at any time
PostPosted: Thu May 22, 2014 1:11 pm
Try this:
ReefAngel.SingleATO(true,Port1,60,0);
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1);
PostPosted: Fri May 23, 2014 12:03 am
Thanx Roberto!
PostPosted: Tue Jun 03, 2014 7:24 am
Hi Guys! Still Strugling here!
Here is a PIC of how my floats are installed
So I want the lower one (ATOLow) to Control the level and the higher one (ATOHigh) for fail safe if something should happen to the Low switch
PostPosted: Tue Jun 03, 2014 7:46 am
photos are not showing :(
PostPosted: Tue Jun 03, 2014 7:54 am
Why?
PostPosted: Tue Jun 03, 2014 7:56 am
They are Installed next to each other! The one higher than the other! With the wires pointing upwards! Hope that makes sense!
PostPosted: Tue Jun 03, 2014 7:57 am
How about now?
PostPosted: Tue Jun 03, 2014 7:59 am
I think it has to do something with tapatalk :(
PostPosted: Tue Jun 03, 2014 8:14 am
Okay! But do you make sense of my description?
Next
