Single ATO
PostPosted: Tue Jun 03, 2014 8:16 am
Yes, but according to your description, the code posted above is what you need.
PostPosted: Tue Jun 03, 2014 8:40 am
It does not work! It works kinda viceversa! When the level is low the relay switches off, when high it switches on! The ATO also keeps Timming out!
PostPosted: Tue Jun 03, 2014 8:42 am
I think you have the float switches connected to the wrong ports.
PostPosted: Tue Jun 03, 2014 9:03 am
Its connected to the 2 Ports left of the pH probe!
PostPosted: Tue Jun 03, 2014 9:09 am
Yes, but I think they are inverted.
PostPosted: Tue Jun 03, 2014 9:14 am
Inverted? Meaning?
PostPosted: Tue Jun 03, 2014 9:23 am
ATO Low is on ATO High and ATO High is on ATO Low
PostPosted: Tue Jun 03, 2014 9:32 am
Nope! Checked that already!
PostPosted: Tue Jun 03, 2014 10:42 am
Then you probably have them upside down :) You can leave them mounted that way. Take the clip off and turn the float magnet upside down then put the clip back. That will reverse the behavior.
Previous
