Single ATO
Posted: Thu May 22, 2014 12:47 pm
by Christo
Hi Guys
If I want to use the SingleATO for the following!
The low-switch controls the sump level and the high-switch to act as a failsafe if the low-switch should get stuck at any time
Re: Single ATO
Posted: Thu May 22, 2014 1:11 pm
Try this:
ReefAngel.SingleATO(true,Port1,60,0);
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1);
Re: Single ATO
Posted: Fri May 23, 2014 12:03 am
by Christo
Thanx Roberto!
Re: Single ATO
Posted: Tue Jun 03, 2014 7:24 am
by Christo
Hi Guys! Still Strugling here!
Here is a PIC of how my floats are installed
So I want the lower one (ATOLow) to Control the level and the higher one (ATOHigh) for fail safe if something should happen to the Low switch
Re: Single ATO
Posted: Tue Jun 03, 2014 7:46 am
photos are not showing :(
Re: Single ATO
Posted: Tue Jun 03, 2014 7:54 am
by Christo
Why?
Re: Single ATO
Posted: Tue Jun 03, 2014 7:56 am
by Christo
They are Installed next to each other! The one higher than the other! With the wires pointing upwards! Hope that makes sense!
Re: Single ATO
Posted: Tue Jun 03, 2014 7:57 am
by Christo
How about now?
Re: Single ATO
Posted: Tue Jun 03, 2014 7:59 am
I think it has to do something with tapatalk :(
Re: Single ATO
Posted: Tue Jun 03, 2014 8:14 am
by Christo
Okay! But do you make sense of my description?
Re: Single ATO
Posted: Tue Jun 03, 2014 8:16 am
Yes, but according to your description, the code posted above is what you need.
Re: Single ATO
Posted: Tue Jun 03, 2014 8:40 am
by Christo
It does not work! It works kinda viceversa! When the level is low the relay switches off, when high it switches on! The ATO also keeps Timming out!
Re: Single ATO
Posted: Tue Jun 03, 2014 8:42 am
I think you have the float switches connected to the wrong ports.
Re: Single ATO
Posted: Tue Jun 03, 2014 9:03 am
by Christo
Its connected to the 2 Ports left of the pH probe!
Re: Single ATO
Posted: Tue Jun 03, 2014 9:09 am
Yes, but I think they are inverted.
Re: Single ATO
Posted: Tue Jun 03, 2014 9:14 am
by Christo
Inverted? Meaning?
Re: Single ATO
Posted: Tue Jun 03, 2014 9:23 am
ATO Low is on ATO High and ATO High is on ATO Low
Re: Single ATO
Posted: Tue Jun 03, 2014 9:32 am
by Christo
Nope! Checked that already!
Re: Single ATO
Posted: Tue Jun 03, 2014 10:42 am
Then you probably have them upside down :) You can leave them mounted that way. Take the clip off and turn the float magnet upside down then put the clip back. That will reverse the behavior.
