Page 1 of 6
Issues I've seen in the current Dev Library.
Posted: Thu Sep 04, 2014 8:21 am
by Sacohen
I'm sure these issues are something with me or else everyone would have mentioned them.
1) The Multi WL sensor does not display anything. With the current Libraries I will at least get levels but with the dev Library the 4 Multi WL sensors display 0.
2) I tried to set up the DDNS server last night and when I add the code and set up my DNS name in there I lose connectivity with my head unit. The Portal will read unavailable and it will start pulling it's info from the web database.
The Android app loses connectivity in Away mode and Reeftronics can not receive any data from it. My DNS name is still set up with No-IP and works fine on the current 1.1.0 Libraries.
Both of these issues are to large for me to be the only one having an issue so I must have dome something incorrectly.
There really is not any code setup for the Multi WL sensor I just monitor the level of my ATO reservoir so I can't say a code issue is causing it to report 0.
The code for the DNS server is have as...
ReefAngel.DDNS("subdomain");
with my subdomian in there.
Re: Issues I've seen in the current Dev Library.
Posted: Thu Sep 04, 2014 8:25 am
Thanks Steve, It's important that we get testers to uncover issues like this.
Hopefully Roberto can address some of your findings, none of the patches I've submitted should have modified this functionality. The DDNS is pretty new, so you may be like the 2nd person using it :)
Posted: Thu Sep 04, 2014 8:46 am
by Sacohen
Technically trying to use it.
I'm not even really using it.
I was going to switch over to the Dev Library and let the Portal update overnight, but the I realized if the Portal is not communicating with the RA then it will never get the DDNS name I entered in the code.
Posted: Thu Sep 04, 2014 9:12 am
Weird. I'm looking at the server and I can see that your DDNS name was entered into the server.
I'm going to delete the entry. Let's see if it gets added again.
BTW, you and I are the only ones so far :cry:
I've been using the DDNS feature on my controller for quite a while now, but I have not updated my controller after Lee and Alan added their stuff, but there was nothing on their end that would change the functionality.
I also use the Multi WL on my tank. If it was not working, my drain pipe would be gargling and making noise :(, which I definitely wouldn't want it to happen. It's the Multi WL that controls my "RobertoFlow" 8-)
Can you post your entire code?
I'm going to load it up in a test controller and see what happens.
Posted: Thu Sep 04, 2014 9:18 am
by Sacohen
No Problem. I'll remote into my laptop and post the code and also change the libraries and upload mu code again with my handy dandy Blue Tooth module :)
Oh is there any security rick posting my code that has my portal key, my DDNS name and my webserver password in it?
Posted: Thu Sep 04, 2014 10:41 am
by Sacohen
Oh one other question.
The code for the DDNS goes in the setup section, correct?
Posted: Thu Sep 04, 2014 10:42 am
by Sacohen
Roberto;
Here's my code...
#include <Wire.h>fF
#include <RA_NokiaLCD.h>f
// Define Relay Ports by Name
#define Actinic_Lights     1
#define Day_Lights         2
#define Kalkwasser         3
#define Pumps              4
#define Sump_Fan           5
#define DeNit_Doser        6
#define DeNit_Pump         7
#define ATO_Pump           8
#define Unused             Box1_Port1
#define Feeder             Box1_Port2
#define Unused             Box1_Port3
#define Unused             Box1_Port4
#define Unused             Box1_Port5
#define Unused             Box1_Port6
#define Unused             Box1_Port7
#define Dummy              Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
ReefAngel.WaterChangePorts = Port4Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit;
//Set Standard Menu
ReefAngel.AddStandardMenu();
//Webserver Authentication
ReefAngel.Network.WifiAuthentication("Sacohen:xxxxxxxx");
//DDNS Server
ReefAngel.DDNS("xxxxxxxx");
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.DCPump.AntiSyncOffset=0;
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
  ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
  ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
  ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
  ReefAngel.WaterLevelATO(ATO_Pump,720,28,31);
  if ( hour()>=13 && hour()<21 )
  ReefAngel.PWM.SetChannel( 5, 0 );
  ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
  //Mix Kalkwasser
static unsigned long Kalk_Mixing = 0;
static unsigned long stopTime = 0;
static byte prevWL=0;
if (ReefAngel.WaterLevel.GetLevel(1)>=100 && prevWL<100) {
  stopTime=now()+3600; // Get time one hour from now.
prevWL = ReefAngel.WaterLevel.GetLevel(1); // Store the water level
if (now() < stopTime) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
  //AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
ReefAngel.Relay.On(Feeder); //TURN FEEDER RELAY ON
ReefAngel.Relay.Off(Feeder); //TURN FEEDER RELAY OFF
} else {
if ( autofeeding > 0 ) {
autofeeding = 0;
  // DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=600;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-DeNit_Offset)%DeNit_Repeat<DeNit_Pump_Runtime);  // Runs denitrator pump
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-DeNit_Offset)-DeNit_Doser_Offset)%DeNit_Repeat<DeNit_Doser_Runtime); // Runs denitrator doser
  // Disable ATO
if ( (now()-3600)%21600<DeNit_ATO_Offtime) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Delay WL ATO after water change and DeNit_Dosing
  static time_t wcTimer=0;
  if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
  // First 10 minutes after WC disable ATO
  if (now()-wcTimer >= 0 && now()-wcTimer < 600)
    // Track Salinity low duration
    static unsigned long lastGoodSal;
    static boolean lowSalFlag;
    // Salinity is good, update counter
    if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
    // Counter hasn't been updating in 300 seconds..
    if (now()-lastGoodSal>300) {
      lowSalFlag=true; // Salinity is definitely below 33.5
    } else {
      lowSalFlag=false; // Salinity back to normal
    // Disable ATO if lowSalFlag is true
    if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Disable ATO if ATO High IsActive()
static int rmode;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  ReefAngel.Portal( "Sacohen","xxxxxxxx" );
int x,y;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
//Salinity
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
I also re uploaded it to my controller so you can see if it shows up in the server again.
Posted: Thu Sep 04, 2014 4:16 pm
by AlanM
I'll try doing the DDNS stuff with mine. I've just been using my default no-ip.org domain so far for the apps and never entered it anywhere in the portal. The portal just figures it out, I assume because my RA reaches out to the portal from time to time.
I also haven't tried any of the authentication stuff yet, and I don't have a ml water sensor, so wouldn't know on that stuff. I just downloaded dev tonight after all the merges and put it on my RA and it all compiled without tweaks and worked without changing my .ino for the dc pump things that I've been using.
Posted: Fri Sep 05, 2014 12:03 pm
by Sacohen
Roberto;
Did you get to see if my code duplicated the problems I'm talking about on your system?
Also did my DNS name repopulate on the server?
Just curious.
Posted: Fri Sep 05, 2014 8:54 pm
The loss of connectivity is because of the authentication. You are requiring every connection the have a username an password entered. The portal doesn't have that implemented it yet. Not sure if reeftronics has it.
Posted: Fri Sep 05, 2014 9:04 pm
The Multi WL actually had a change made by brunnels a while ago.
You need this in the setup section:
ReefAngel.AddMultiChannelWaterLevelExpansion();
And you will need to add which channel you want to use the WaterLevelATO:
ReefAngel.WaterLevelATO(0,ATO_Pump,720,0,1);
Where the first argument is the channel.
Posted: Fri Sep 05, 2014 9:11 pm
I'm not even sure how you got it to compile, because it was failing for me.
Did you update your features file with the latest?
I recommend getting the latest features.txt file from here: https://github.com/reefangel/FeaturesAn ... master.zip
And the latest dev from here: https://github.com/reefangel/Libraries/archive/dev.zip
Posted: Sat Sep 06, 2014 5:54 am
by Sacohen
I got the latest dev downloaded 9/3, that should have the latest features.txt in it.
I added the code for the WL and re-uploaded.
Confirmed that the WL works and the server authentication works on the Andriod App.
Commented out the server authentication in my code and re-uploaded to the unit to watch it for a while and see if the DDNS work. (I'm sure it will).
Thanks Roberto.
Posted: Sat Sep 06, 2014 6:31 am
by cosmith71
What do I do with the feature.txt file?
Posted: Sat Sep 06, 2014 6:45 am
by Sacohen
I wasn't sure about that either.
I can't wait to try your new lighting code, but one of my LED channels in one of my lights died so I haven't tried anything yet.
Posted: Sat Sep 06, 2014 7:09 am
by AlanM
The new feature.txt doesn't come with the Libraries update even if you get the Dev version. You should get it from the separate Features zip file Roberto posted a few posts up.
Mine lives at C:\Username\My Documents\Arduino\update\feature.txt
You'd replace that file with the one downloaded in the .zip.
Posted: Sat Sep 06, 2014 7:11 am
by cosmith71
Steve: You should. It's awesome. :D
Alan: Thanks, I thought that's where it went, but wasn't sure.
I'll give the new libraries a try.
Posted: Sat Sep 06, 2014 7:32 am
by Sacohen
Thanks AlanM.
I may want to pick your brain about the D120 LED mod.
I saw you did a lot of testing on that
Posted: Sat Sep 06, 2014 7:33 am
by cosmith71
OK, so I got the 1.1.1 libraries loaded. Everything is good so far with my old code.
DDNS seems to be working for the portal. How do I get it to work with the Reef Angel Status app? It tells me "Unknown Host: http://cosmith71_120.reefangel.com:2000/r99
Posted: Sat Sep 06, 2014 7:52 am
by AlanM
Sacohen wrote:Thanks AlanM.
I only have a d120 over my fuge, so I stopped messing with it, but it worked well. Basically take the two dimming wires that go to the pot and run 0-10V on them in the right direction. 8) The arduino hardware in the relay box seems to be not as fragile as whatever the Apex has because the Apex folks freaked out when I said at 0V it put a teensy amount of current back in the other direction to dim all the way, but Roberto seemed to think it was no big deal.
I owe Roberto a bunch of usage notes for the dev code since a few of us have made some changes that people will really like if they decide to use them. Some of the stuff is under the hood and should just work without changes to the INO, but some would be fun for people to play with (new light and pump profiles).
Everyone with a non-Plus version of the ReefAngel is going to be missing out on increasingly more fun stuff.
Posted: Sat Sep 06, 2014 7:55 am
by Sacohen
Colin;
Did you enter username_DNSName.myreefangel.com
Like Roberto's example rimai_home.myreefangel.com from here http://forum.reefangel.com/viewtopic.ph ... DNS#p40874
Posted: Sat Sep 06, 2014 7:56 am
by AlanM
BTW, Colin. I'd like to take a crack at getting your cloud/lightning code into the RA_PWM class if that's OK with everyone. It would likely be something like ReefAngel.PWM.SetCloud[x] = y. Where you could set the cloud parameters for channel X to Y. I hadn't looked in detail at the arguments that your code takes.
What do you think about adding it to the libraries? Seems like something that all the "advanced" schmancy new lighting controllers (bluefish, storm x, etc) all include.
Posted: Sat Sep 06, 2014 7:58 am
by Sacohen
Thanks.
I may switch over the the new 2014 knockoff model if I can't get the guy I bought the nes I have to repair one of mine or replace it with a newer model because they don't make the model I got anymore.
Posted: Sat Sep 06, 2014 7:59 am
by binder
cosmith71 wrote:OK, so I got the 1.1.1 libraries loaded. Everything is good so far with my old code.
It could not have propagated through the DNS servers yet. I don't recall the TTL value (how frequent the DNS records get updated) that Roberto is using. It may take up to 24 hours for it to be ready and in use with all DNS servers.
Posted: Sat Sep 06, 2014 8:01 am
by Sacohen
AlanM wrote:The new feature.txt doesn't come with the Libraries update even if you get the Dev version. You should get it from the separate Features zip file Roberto posted a few posts up.
I don't have an update folder in any version of the libraries I have. DO I just create the folder and put it in there?
Posted: Sat Sep 06, 2014 8:21 am
by cosmith71
I was wondering about that. Patience isn't always my strong suit. :D
Posted: Sat Sep 06, 2014 8:23 am
by cosmith71
AlanM wrote:BTW, Colin. I'd like to take a crack at getting your cloud/lightning code into the RA_PWM class if that's OK with everyone. It would likely be something like ReefAngel.PWM.SetCloud[x] = y. Where you could set the cloud parameters for channel X to Y. I hadn't looked in detail at the arguments that your code takes.
Lee had mentioned it but hadn't done any work yet. I thought I'd give it a try as a learning experience, but I'm thinking it would take me forever and still may be beyond my level right now. So, go for it!
Posted: Sat Sep 06, 2014 8:25 am
by Sacohen
I'm having the same issue. The Portal just updated to my new IP address after I disabled my no-ip host, but the Android app is giving me an "Error 14: Unknown Host:sacohen_myreeftank.myreefangel.com:2000//r99".
If the Portal is seeing it then shouldn't the App see it?
cosmith71 wrote: It could not have propagated through the DNS servers yet. I don't recall the TTL value (how frequent the DNS records get updated) that Roberto is using. It may take up to 24 hours for it to be ready and in use with all DNS servers.
--Colin[/quote]
Same with me :)
Posted: Sat Sep 06, 2014 8:30 am
I can confirm that both entries for Colin and Steve are in the DNS server.
So, we've got 3 so far :)
Posted: Sat Sep 06, 2014 8:41 am
Colin, i noticed you had .reefangel.com but the examples are .myreefangel.com not sure if you already saw that or not.
