Issues I've seen in the current Dev Library.
Re: Issues I've seen in the current Dev Library.
How about long pulse / short pulse etc when chosen manually?
It's in NTM after feeding right now.
I'll double check them later, but I think they were fine.
I was watching TV while waiting for NTM for finished and noticed that my moonlights were flashing.
https://www.youtube.com/watch?v=luKhY1D7fFI
I've never had this happen before. I don't know if it is the new code or what.
I looked at the Andriod app and the Portal and all the channels on the dimming module were at 50%, but I caught an update a little later and they were all at 0.
I tried rebooting and the same issues.
After NTM it went to Lagoonal Mode and the moonlights stayed on at 50% (no flashing).
I manually set it to Short Pulse and it is pulsing at 50%, but so are all channels on the dimming port.
The dimming pory seems to be following the Daylight Channel of the Relay. The same thing is happening in Long Pulse, but at a slower rate.
I just checked and it's happening with all the wave modes.
Whatever percentage the Daylight Dimming Channel is at all the channels on the Dimming Module are at the same percentage.
Just double checked and it does not happen with the old libraries and my old code for that set of libraries.
I was wondering if it had to do with the offset code, so I commented it out and it still happens, so it's not that.
But is it when in custom or all the modes? Can you try a wizard code i need to look at your ino again...
It's all modes when changed thru the Internal Memory.
I'll try some Wizard code and let you know.
Created a totally Wizard code (the only thing I went back in and added was my Portal Key) and Moonlights still flashed while the channels on the Dimming Module were still matching the Daylight Dimming port on the Relay.
Ok. Thanks. I'll see if any issue I can find. Alan, how about you are you seeing similar?
No. I don't see those issues, I don't have a 6 channel dimmer, though, and you don't have DC pumps, so maybe we would miss them. I'll look again at the reefangel .cpp stuff to see if somehow the pump settings are getting sent to all the lights or something for the expansion.
I've added the DCPump to my sketch and running my two unused ports as DCPumps. Let's see if I get similar issues.
Ok, I've definitely been able to reproduce it. I'm working on the issue now. It seems that the else got inside the hardware #ifdefs so it probably wasn't being seen on the current RA boards.
Yep, good values in Serial Monitor now. Going to remove the debug code and let it run. I'll verify shortly when I have positive results via the wifi. I'll have the code posted and a pull request ready to go
The error was only in the PWM expansion and not in the other code and not repeated in the sixteen channel.
OK, the r99 output looks great. It is no longer affecting the other channels on the PWM expansion and it is setting the antisync channel properly. Before it was getting 0 and every channel was getting the Sync speed. It was a misplaced else that got inside the wrong #define. I also added some braces, but I think they weren't needed, but they're in the current pull request and updated in the pumpoffset branch.
Enjoy
Enjoy
And with that said, Roberto has merged the request You can re-download the official dev version
Here's all my pwm channels graphed. Looks pretty good to me
http://forum.reefangel.com/status/chart ... lter=pwme5
Looks good.
Downloaded and replaced the libraries.
Uploaded my text code to the unit and looking at the Portal my pumps are running at 30% (like they should be at night), but the moonlights are at 86% (Like they should be running the MoonPhase).
Hopefully that's the last of the issues and Roberto can distribute this version so everyone can enjoy all the new features.
Off Topic: What is the pattern for the Gyre wave mode?
It s a sine wave, but the two pumps slow down and speed up before they switch direction
And its one pump on while other is off.
Think of Gyre like long pulse with rounded corners.
Oh. I remember you posting about it now.
I didn't know that was the name.
Everything has been running well with the new code.
One thing I did notice and I'm not sure if it was intentional or not was when with the current released libraries when I had the portal set to custom and I was running my random wave modes that Lee created the portal would display the actual wave mode that was running that day (Lagoonal, Short, Pulse ReefCrest, etc) with the dev libraries it displays Custom.
For me it was kind of nice knowing what mode was running that day or seeing that the mode actually changed when I reboot the controller.
Just something I wanted to mention.
Thanks;
Thanks;
That may be something in the portal. Are you looking in the Internal Memory section or on the portal main page. What's odd is that when the mode is custom we set memory to false and set the mode to the appropriate mode so it should be showing the correct mode. What do you see for DCM in the r99 output?
I will look at the r99 when I get home, but I'm talking about the display on the portal, not the internal memory.
The Internal memory displays correctly as Custom 50/30
This is an older screen shot.
This one on the new library.
DCM in the r99 output is 11lnevo wrote:What do you see for DCM in the r99 output?
That makes no sense we override the mode to the random setting. what happens when you're in night or feeding mode? and by feeding mode, I mean the time when you should have nutrient transport...
When I go into feeding mode the Jebao pumps go off for 15 min and the Portal and U-App display Nutrient Transport Mode 50/30
DCM = 5
After the 15 min the Portal and U-App display Nutrient Transport Mode 50/30
DCM = 5
In night mode the Portal and U-App display Constant 30/30
DCM = 0
DCM = 5
DCM = 5
DCM = 0
That's wierd, we're not doing anything different with the modes when we're in the random section. we set the mode to the appropriate mode. Do the pumps look like they're doing the right then when they're in the random selection?
I'm not sure. I'm at work most of the time they are in Random mode.
By the time I get home they are in NTM from after feeding then between 7 and 10pm they go back to Random.
I'll have to look at it more carefully tomorrow.
I see your problem. In the first page when you were troubleshooting the DNS code you posted your modified INO...
You have this code for the custom section:
In your original code you have this:
So it seems you took too much out
This is what that section should look like:
And finally here is your updated future 1.1.11 code should look like:
if (modes[rmode]==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true ); // ElseMode on sync mode, Portal Speed Setting +/- 20%
#include <Wire.h>fF
#include <RA_NokiaLCD.h>f
// Define Relay Ports by Name
#define Actinic_Lights 1
#define Day_Lights 2
#define Kalkwasser 3
#define Pumps 4
#define Sump_Fan 5
#define DeNit_Doser 6
#define DeNit_Pump 7
#define ATO_Pump 8
#define Unused Box1_Port1
#define Feeder Box1_Port2
#define Unused Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Dummy Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
//Set Standard Menu
ReefAngel.AddStandardMenu();
//Webserver Authentication
ReefAngel.Network.WifiAuthentication("Sacohen:xxxxxxxx");
//DDNS Server
ReefAngel.DDNS("xxxxxxxx");
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.DCPump.AntiSyncOffset=0;
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
ReefAngel.WaterLevelATO(ATO_Pump,720,28,31);
if ( hour()>=13 && hour()<21 )
ReefAngel.PWM.SetChannel( 5, 0 );
ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
//Mix Kalkwasser
static unsigned long Kalk_Mixing = 0;
static unsigned long stopTime = 0;
static byte prevWL=0;
if (ReefAngel.WaterLevel.GetLevel(1)>=100 && prevWL<100) {
stopTime=now()+3600; // Get time one hour from now.
prevWL = ReefAngel.WaterLevel.GetLevel(1); // Store the water level
if (now() < stopTime) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
//AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
if ( autofeeding > 0 ) {
autofeeding = 0;
// DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=600;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-DeNit_Offset)%DeNit_Repeat<DeNit_Pump_Runtime); // Runs denitrator pump
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-DeNit_Offset)-DeNit_Doser_Offset)%DeNit_Repeat<DeNit_Doser_Runtime); // Runs denitrator doser
// Disable ATO
if ( (now()-3600)%21600<DeNit_ATO_Offtime) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
// Delay WL ATO after water change and DeNit_Dosing
static time_t wcTimer=0;
// First 10 minutes after WC disable ATO
if (now()-wcTimer >= 0 && now()-wcTimer < 600)
// Track Salinity low duration
static unsigned long lastGoodSal;
static boolean lowSalFlag;
// Salinity is good, update counter
if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
// Counter hasn't been updating in 300 seconds..
if (now()-lastGoodSal>300) {
lowSalFlag=true; // Salinity is definitely below 33.5
lowSalFlag=false; // Salinity back to normal
// Disable ATO if lowSalFlag is true
if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
// Disable ATO if ATO High IsActive()
static int rmode;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
// Night mode (go to 30%)
ReefAngel.DCPump.Speed=30;
ReefAngel.Portal( "Sacohen","xxxxxxxx" );
int x,y;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
//Salinity
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
