Issues I've seen in the current Dev Library.
Re: Issues I've seen in the current Dev Library.
Colin;
Did you enter username_DNSName.myreefangel.com
Like Roberto's example rimai_home.myreefangel.com from here http://forum.reefangel.com/viewtopic.ph ... DNS#p40874
BTW, Colin. I'd like to take a crack at getting your cloud/lightning code into the RA_PWM class if that's OK with everyone. It would likely be something like ReefAngel.PWM.SetCloud[x] = y. Where you could set the cloud parameters for channel X to Y. I hadn't looked in detail at the arguments that your code takes.
What do you think about adding it to the libraries? Seems like something that all the "advanced" schmancy new lighting controllers (bluefish, storm x, etc) all include.
Thanks.AlanM wrote:I only have a d120 over my fuge, so I stopped messing with it, but it worked well. Basically take the two dimming wires that go to the pot and run 0-10V on them in the right direction. 8) The arduino hardware in the relay box seems to be not as fragile as whatever the Apex has because the Apex folks freaked out when I said at 0V it put a teensy amount of current back in the other direction to dim all the way, but Roberto seemed to think it was no big deal.Sacohen wrote:Thanks AlanM.
I may want to pick your brain about the D120 LED mod.
I saw you did a lot of testing on that
I owe Roberto a bunch of usage notes for the dev code since a few of us have made some changes that people will really like if they decide to use them. Some of the stuff is under the hood and should just work without changes to the INO, but some would be fun for people to play with (new light and pump profiles).
Everyone with a non-Plus version of the ReefAngel is going to be missing out on increasingly more fun stuff.
I may switch over the the new 2014 knockoff model if I can't get the guy I bought the nes I have to repair one of mine or replace it with a newer model because they don't make the model I got anymore.
It could not have propagated through the DNS servers yet. I don't recall the TTL value (how frequent the DNS records get updated) that Roberto is using. It may take up to 24 hours for it to be ready and in use with all DNS servers.cosmith71 wrote:OK, so I got the 1.1.1 libraries loaded. Everything is good so far with my old code.
DDNS seems to be working for the portal. How do I get it to work with the Reef Angel Status app? It tells me "Unknown Host: http://cosmith71_120.reefangel.com:2000/r99
I don't have an update folder in any version of the libraries I have. DO I just create the folder and put it in there?AlanM wrote:The new feature.txt doesn't come with the Libraries update even if you get the Dev version. You should get it from the separate Features zip file Roberto posted a few posts up.
Mine lives at C:\Username\My Documents\Arduino\update\feature.txt
You'd replace that file with the one downloaded in the .zip.
I was wondering about that. Patience isn't always my strong suit.binder wrote:It could not have propagated through the DNS servers yet. I don't recall the TTL value (how frequent the DNS records get updated) that Roberto is using. It may take up to 24 hours for it to be ready and in use with all DNS servers.cosmith71 wrote:OK, so I got the 1.1.1 libraries loaded. Everything is good so far with my old code.
Lee had mentioned it but hadn't done any work yet. I thought I'd give it a try as a learning experience, but I'm thinking it would take me forever and still may be beyond my level right now. So, go for it!AlanM wrote:BTW, Colin. I'd like to take a crack at getting your cloud/lightning code into the RA_PWM class if that's OK with everyone. It would likely be something like ReefAngel.PWM.SetCloud[x] = y. Where you could set the cloud parameters for channel X to Y. I hadn't looked in detail at the arguments that your code takes.
I'm having the same issue. The Portal just updated to my new IP address after I disabled my no-ip host, but the Android app is giving me an "Error 14: Unknown Host:sacohen_myreeftank.myreefangel.com:2000//r99".binder wrote:It could not have propagated through the DNS servers yet. I don't recall the TTL value (how frequent the DNS records get updated) that Roberto is using. It may take up to 24 hours for it to be ready and in use with all DNS servers.cosmith71 wrote:OK, so I got the 1.1.1 libraries loaded. Everything is good so far with my old code.
If the Portal is seeing it then shouldn't the App see it?
I was wondering about that. Patience isn't always my strong suit.cosmith71 wrote: It could not have propagated through the DNS servers yet. I don't recall the TTL value (how frequent the DNS records get updated) that Roberto is using. It may take up to 24 hours for it to be ready and in use with all DNS servers.
--Colin[/quote]
Same with me
I can confirm that both entries for Colin and Steve are in the DNS server.
So, we've got 3 so far
Colin, i noticed you had .reefangel.com but the examples are .myreefangel.com not sure if you already saw that or not.
Thanks Roberto. I'll try to be patient.
See if you can ping your domain name:
ping rimai_home.myreefangel.com
Not always. The portal is using robertos DNS servers. Your app is using your DNS servers. the ReefAngel DNS servers will see the changes instantly. Your ISP/providers DNS servers will get the changes/updates whenever they get propagated. So, unfortunately, you will have to wait and keep checking when the changes propagate.Sacohen wrote: I'm having the same issue. The Portal just updated to my new IP address after I disabled my no-ip host, but the Android app is giving me an "Error 14: Unknown Host:sacohen_myreeftank.myreefangel.com:2000//r99".
I have that. I transcribed it wrong.lnevo wrote:Colin, i noticed you had .reefangel.com but the examples are .myreefangel.com not sure if you already saw that or not.
Unable to ping rimai_home.myreefangel.com
C:\Users\Steve>ping rimai_home.myreefangel.com
Ping request could not find host rimai_home.myreefangel.com. Please check the na
me and try again.
me and try again.
not mine... yours.... lol
That domain is not existent. I just used it as example
Yes.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Steve>ping sacohen_myreeftank.myreefangel.com
Pinging sacohen_myreeftank.myreefangel.com [65.3.96.176] with 32 bytes of data:
Reply from 65.3.96.176: bytes=32 time=3ms TTL=64
Ping statistics for 65.3.96.176:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 3ms, Average = 3ms
C:\Users\Steve>
C:\Users\Steve>
I've also noticed that my Jebao pumps don't seem to be right.
The WP-40 (Actinic/Anti-Sync) is at a constant 66% while the WP-25 (Daylight/Sync) is at 0.
I have the internal memory set to custom with a speed of 50 and a duration of 30.
The DCPump section does display this correctly, but it never changes.
If it happened to be on Constant Mode in the Random code it would be 50% on both channels.
Short and Long Pulse will alternate 50/0 between pumps with varying lengths depending upon short or long.
Else, Lagoon or ReefCrest will show varying percentages and opposite each other (Anti Sync).
After a reboot I had 0% on both channels, which I have never had.
Never Mind I think the Internal Memory of the Portal got set to Constant 0/0.
Not sure how. I never set it to that.
No something is not right.
Else mode works properly and it seems that Sine does too, but when I try Grye or Custom (which triggers the Random code Lee created) both pumps goe to 0 speed.
How about long pulse / short pulse etc when chosen manually?
It's in NTM after feeding right now.
I'll double check them later, but I think they were fine.
I was watching TV while waiting for NTM for finished and noticed that my moonlights were flashing.
https://www.youtube.com/watch?v=luKhY1D7fFI
I've never had this happen before. I don't know if it is the new code or what.
I looked at the Andriod app and the Portal and all the channels on the dimming module were at 50%, but I caught an update a little later and they were all at 0.
I tried rebooting and the same issues.
After NTM it went to Lagoonal Mode and the moonlights stayed on at 50% (no flashing).
I manually set it to Short Pulse and it is pulsing at 50%, but so are all channels on the dimming port.
The dimming pory seems to be following the Daylight Channel of the Relay. The same thing is happening in Long Pulse, but at a slower rate.
I just checked and it's happening with all the wave modes.
Whatever percentage the Daylight Dimming Channel is at all the channels on the Dimming Module are at the same percentage.
Just double checked and it does not happen with the old libraries and my old code for that set of libraries.
I was wondering if it had to do with the offset code, so I commented it out and it still happens, so it's not that.
But is it when in custom or all the modes? Can you try a wizard code i need to look at your ino again...
It's all modes when changed thru the Internal Memory.
I'll try some Wizard code and let you know.
Created a totally Wizard code (the only thing I went back in and added was my Portal Key) and Moonlights still flashed while the channels on the Dimming Module were still matching the Daylight Dimming port on the Relay.
Ok. Thanks. I'll see if any issue I can find. Alan, how about you are you seeing similar?
No. I don't see those issues, I don't have a 6 channel dimmer, though, and you don't have DC pumps, so maybe we would miss them. I'll look again at the reefangel .cpp stuff to see if somehow the pump settings are getting sent to all the lights or something for the expansion.
