Can ReefAngel.Use2014 Screen import portal labels?
PostPosted: Sat Dec 13, 2014 12:53 am
I upgraded to the Reef Angel version 1.1.1 libraries and noticed there is a new Reef Angel screen option named ReefAngel.Use2014Screen(). I added the following code to my INO.
ReefAngel.Use2014Screen();
The new screen appears to be working but I am curious if I can import the custom labels that I have created in the portal to the Reef Angel console? If so, what command(s) do I need to add to my INO to import the portal labels?
PostPosted: Sat Dec 13, 2014 4:29 am
This. First set is the first relay box, second and third sets are expansion relays. Just use however many sets you need. Put them under setup().
 // Define labels for LCD screen
  ReefAngel.CustomLabels[0]="Fan";
  ReefAngel.CustomLabels[1]="Heater";
  ReefAngel.CustomLabels[2]="Skimmer";
  ReefAngel.CustomLabels[3]="Return";
  ReefAngel.CustomLabels[4]="Swabbie";
  ReefAngel.CustomLabels[5]="Sump Light";
  ReefAngel.CustomLabels[6]="Canopy Fans";
  ReefAngel.CustomLabels[7]="Refugium Light";
  ReefAngel.CustomLabels[Box1_Port1Label] = "Alk Pump";
  ReefAngel.CustomLabels[Box1_Port2Label] = "Cal Pump";
  ReefAngel.CustomLabels[Box1_Port3Label] = "Top Off";
  ReefAngel.CustomLabels[Box1_Port4Label] = "";
  ReefAngel.CustomLabels[Box1_Port5Label] = "";
  ReefAngel.CustomLabels[Box1_Port6Label] = "";
  ReefAngel.CustomLabels[Box1_Port7Label] = "";
  ReefAngel.CustomLabels[Box1_Port8Label] = "";
  ReefAngel.CustomLabels[Box2_Port1Label] = "Virt Alk";
  ReefAngel.CustomLabels[Box2_Port2Label] = "Virt Cal";
  ReefAngel.CustomLabels[Box2_Port3Label] = "";
  ReefAngel.CustomLabels[Box2_Port4Label] = "";
  ReefAngel.CustomLabels[Box2_Port5Label] = "";
  ReefAngel.CustomLabels[Box2_Port6Label] = "";
  ReefAngel.CustomLabels[Box2_Port7Label] = "";
  ReefAngel.CustomLabels[Box2_Port8Label] = "";
PostPosted: Sat Dec 13, 2014 7:19 am
cosmith71 wrote:This. First set is the first relay box, second and third sets are expansion relays. Just use however many sets you need. Put them under setup().
Thanks Colin.
PostPosted: Sat Dec 13, 2014 7:34 am
I hoped there was a Reef Angel function that would work similar to the "Download Labels from Portal" that exists in the Reef Angel U-App and the Reef Angel Android app. Then I would only have to update the labels one time in the portal for use with the Reef Angel LCD console and all of the other companion apps.
Also Colin's suggestion works for the relays but does not provide custom labels for the temperature (T1, T2, T3) or pH probes.
