Jebao Not Functioning with New Library
Posted: Sun Dec 14, 2014 9:13 pm
I've been running the same code for nearly a year to control my Jebao powerhead. I had to replace the powerhead with another Jebao and in doing so wanted to change some of the max speed values in Short and Long PulseMode. I updated the libraries just prior to uploading the changes and now the new Jebao won't run. It turns on full speed while uploading, but as soon as the code runs...nothing. Not sure what has changed that is causing the problem.
#include <SunLocation.h>
#include <WiFiAlert.h>
// Custom menus
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Feeding Mode";
prog_char menu2_label[] PROGMEM = "Coral Feeding";
prog_char menu3_label[] PROGMEM = "Water Change";
prog_char menu4_label[] PROGMEM = "ATO Clear";
prog_char menu5_label[] PROGMEM = "Overheat Clear";
prog_char menu6_label[] PROGMEM = "PH Calibration";
prog_char menu7_label[] PROGMEM = "Date / Time";
menu4_label, menu5_label, menu6_label,
menu7_label
// Define Custom Memory Locations
#define Mem_B_MaintGFO 145
#define Mem_B_MaintCal 146
#define Mem_B_MaintAlk 147
#define Mem_B_MaintWC 148
#define Mem_B_MaintATO 149
#define Mem_B_MaintFeeding 150
#define Mem_B_MaintSkimmer 151
#define Mem_B_PrintDebug 198
#define Mem_B_ResetMemory 199
void init_memory() {
InternalMemory.write(Mem_B_ResetMemory,false);
#define NUMBERS_8x16
int ScreenID=1;
// Setup on controller startup/reset
ReefAngel.Init();
//Initialize controller
ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize Menu
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit;
ReefAngel.AddWifi();
ReefAngel.DCPump.WaterChangeSpeed=30;
// Ports that default on
ReefAngel.Relay.On( Port1 ); ////Jebao Wavemaker
ReefAngel.Relay.On( Port3 ); ////Reactor
ReefAngel.Relay.On( Port7 ); ////Filter
ReefAngel.Relay.On( Port8 ); ////Skimmer
// Ports that default off
ReefAngel.Relay.Off( Port5 );
ReefAngel.RF.UseMemory=false;
randomSeed(now()/SECS_PER_DAY);
if (InternalMemory.read(Mem_B_ResetMemory))
init_memory();
void powerHead() {ReefAngel.WavemakerRandom(Port5,2,5);} // Turn Port5 on/off random cycles that lasts from 5 to 10 secs
ReefAngel.StandardHeater( Port4,780,785 );
ReefAngel.StandardFan ( Port6,785,786 );
//ATO runs for up to 4 min every 2 hours
ReefAngel.SingleATO( true,Port2,240,2 );
//Jebao Post Feeding, ReefCrest and Night Time modes
static unsigned long feeding;
if (now()-feeding<3600) {
// Continue NTM for the 60 minutes
ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,65,900,true) ); // Nutrient Transport on sync mode
powerHead();
//vacation mode
if ((hour()>9 && hour()<21))
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,80,900,true));
powerHead();
ReefAngel.PWM.SetDaylight( LongPulseMode(0,50,2,true));
powerHead();
//ATO timeout alert
ReefAngel.CustomVar[0]=InternalMemory.read(ATO_Single_Exceed_Flag);
ReefAngel.CustomVar[7]=255;
ReefAngel.Portal("ReefingHavoc");
// Menu Code
void MenuEntry1(){
ReefAngel.FeedingModeStart();
void MenuEntry2() //"Feed Coral"
// Turns off all pumps (only heater is on) for 15 minuts. Skimmer will turn on for 15 minutes
// followd by all pumps.
// clear the screen
ReefAngel.LCD.DrawText(COLOR_MIDNIGHTBLUE, DefaultBGColor, 5, 10, "Coral Feeding");
ReefAngel.Relay.Off(Port1);
ReefAngel.Relay.Off(Port3);
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port7);
ReefAngel.Relay.Off(Port8);
ReefAngel.Relay.Write();
char msg[8];
bool done = false;
int t;
byte row;
for ( byte i = 0; i < 2; i++ )
sprintf(msg, "Phase %d", i+1);
// leave a blank row and start on the 3rd line
row = MENU_START_ROW*(i+3);
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, row, msg);
if ( i == 1 )
// second time through, we enter phase 2, so shutoff the wavemaker now
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,45,900,true) );
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port8);
// start the feeding timer
ReefAngel.Timer[FEEDING_TIMER].Start();
do
// just loop until the joystick button is pressed or the timer is triggered
// then break out of the loop and proceed
#if defined WDT || defined WDT_FORCE
wdt_reset();
#endif // defined WDT || defined WDT_FORCE
// update the timer on the screen
t = ReefAngel.Timer[FEEDING_TIMER].Trigger - now();
if ( (t >= 0) && ! ReefAngel.Timer[FEEDING_TIMER].IsTriggered() )
ReefAngel.LCD.Clear(DefaultBGColor,60+(intlength(t)*5),row,100,row+8);
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,60,row,t);
delay(200); // to keep from redraw flicker on timer
done = true;
if ( ReefAngel.Joystick.IsButtonPressed() )
// joystick button pressed, so we stop
done = true;
while ( ! done );
wdt_reset();
// reset the variable for the inner do while loop
done = false;
// Restore ports & return to the main screen
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port7);
ReefAngel.ExitMenu();
void MenuEntry3() {
if(ReefAngel.Timer[FEEDING_TIMER].Trigger - now() >= 0)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,60,900,true)); // Nutrient Transport on sync mode
ReefAngel.PWM.SetDaylight( LongPulseMode(0,45,2,true));
void MenuEntry4() {
ReefAngel.ATOClear();
void MenuEntry5() {
ReefAngel.OverheatClear();
void MenuEntry6() {
ReefAngel.SetupCalibratePH();
void MenuEntry7() {
ReefAngel.SetupDateTime();
// Custom Main Screen
void DrawCustomMain() {
const int NumScreens=3;
static boolean drawGraph=true;
// Main Header
ReefAngel.LCD.DrawText(COLOR_DARKSLATEBLUE, DefaultBGColor, 30, 2 , "SPENCER'S REEF");
ReefAngel.LCD.DrawDate(5,112);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
// Param Header
DrawParams(5,14);
switch (ScreenID) {
case 0:
if (drawGraph) {
ReefAngel.LCD.DrawGraph(5,40);
drawGraph=false;
break;
case 1:
DrawStatus(5,40);
break;
// Date+Time
// ReefAngel.LCD.DrawDate(5,122);
if (ReefAngel.Joystick.IsLeft()) {
ScreenID--;
drawGraph=true;
if (ReefAngel.Joystick.IsRight()) {
ScreenID++;
drawGraph=true;
if (ScreenID<0) ScreenID=NumScreens-1;
if (ScreenID>=NumScreens) ScreenID=0;
void DrawCustomGraph() {
if (ScreenID==0)
ReefAngel.LCD.DrawGraph(5, 40);
void DrawParams(int x, int y) {
char buf[16];
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+5,y,"Temp:");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+80, y, "PH:");
// Temp and PH
y+=2;
ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, x+45, y, buf);
y+=6;
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
y+=5;
ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, x+45, y, buf);
void DrawStatus(int x, int y) {
int t=x;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_GREEN);
else {
ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_RED);
if (ReefAngel.LowATO.IsActive()) {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_GREEN);
else {
ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_RED);
y+=12;
