// Autogenerated file by RAGen (v1.0.3.79), (05/02/2011 22:20)
// RA_050211_2220.pde
#define VersionMenu
#define wifi
#define RelayExp
#define SaveRelayState
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
// Timer used to indicate when to dump the parameters
ReefAngel_TimerClass ParamTimer;
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "phanashiro";
prog_char probe3_label[] PROGMEM = "Not%20Used";
prog_char relay1_label[] PROGMEM = "Skimmer";
RA_050211_2220.cpp.o: In function `loop':
C:\Users\PH250023\AppData\Local\Temp\build6451466237859308872.tmp/RA_050211_2220.cpp:94: undefined reference to `ReefAngelClass::WebBanner()'
RA_050211_2220.cpp.o: In function `setup':
C:\Users\PH250023\AppData\Local\Temp\build6451466237859308872.tmp/RA_050211_2220.cpp:62: undefined reference to `ReefAngelClass::LoadWebBanner(int, unsigned char)'
I have no idea about what is causing this error.
Can somebody help me to fix this?
Thanks..
Paulo
