Another error: 'class ReefAngelClass' has no member named 'W
paulo.hanashiro
Post by paulo.hanashiro »
Hi Curt.
I found another problem, and this time (IMHO) it looks like a bug in the processHTTP().
As I don't want wavemakers, I commented the "#define WavemakerSetup" at ReefAngel_Features.h.
Now when I try to verify my code, I'm having this error.
C:\Users\PH250023\Documents\Pessoal\ReefAngel\ReefAngel 2.0\arduino-0022\libraries\ReefAngel_Wifi\ReefAngel_Wifi.cpp: In function 'void processHTTP()':
C:\Users\PH250023\Documents\Pessoal\ReefAngel\ReefAngel 2.0\arduino-0022\libraries\ReefAngel_Wifi\ReefAngel_Wifi.cpp:281: error: 'class ReefAngelClass' has no member named 'WM1Port'
C:\Users\PH250023\Documents\Pessoal\ReefAngel\ReefAngel 2.0\arduino-0022\libraries\ReefAngel_Wifi\ReefAngel_Wifi.cpp:285: error: 'class ReefAngelClass' has no member named 'WM2Port'
And it works fine uncommenting the "WavemakerSetup" feature.
Do we need some ifdef?
I did this in my lib ReefAngel_Wifi.cpp
#ifdef WavemakerSetup
					if ( (webmemoryloc == Mem_I_WM1Timer) || (webmemoryloc == Mem_I_WM2Timer) )
						// Restart wavemaker timers once they are set
						byte i = 1;
						byte p = ReefAngel.WM1Port;
						if ( webmemoryloc == Mem_I_WM2Timer )
							i = 2;
							p = ReefAngel.WM2Port;
						ReefAngel.Timer[i].Trigger = 0;
						ReefAngel.Timer[i].SetInterval(weboption);
						ReefAngel.Timer[i].Start();
						ReefAngel.Relay.On(p);
#endif
Thanks in advance.
Paulo
Re: Another error: 'class ReefAngelClass' has no member name
Yeah, there is another bug in the ProcessHTTP() code that was found several weeks ago. It is only noticeable when you have wifi enabled and you have no wavemakers enabled. Somebody just asked this same question earlier today. See this thread for my solution.
http://forum.reefangel.com/viewtopic.php?f=12&t=47
